12-23-2008, 02:31 AM | #1 |
bucket questions
I have a couple of questions for the resto people.
I need some help on id'ing the proper set of bucket seats and console used for a 1968 C10 (sw). Pics would be great. I've also read that I will need a big hump T-cover for my turbo 400. And I was told there was a difference in the firewall on the big block trucks. Is this true? |
12-23-2008, 03:02 AM | #2 | |
Still livin the "dream" in '54
Re: bucket questions
BTW, welcome to the site from we-never-have-winter-southern Arizona!!! It was almost shorts weather here today!!! Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 12-23-2008 at 03:04 AM. |
12-23-2008, 03:13 AM | #3 |
Recovering 67-72 Addict
Here are the correct bucket seats for a 67-68:
http://67-72chevytrucks.com/vboard/s...d.php?t=311205
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
12-23-2008, 04:00 AM | #4 | |
12-23-2008, 09:28 AM | #5 |
My 69 came from the factory with a TH 400 and low hump, so I know it will fit. I really don't know for sure why they put the larger hump in some trucks?
"Negative people always seem to have a problem for every solution" |
12-23-2008, 10:22 AM | #6 |
The hump difference is low (built in)or high (removeable)... BUT, 2WD bigblocks have a slightly shorter high hump than 4WD. 2WD small blocks and six cylinders had the low hump.
You are looking for buddy buckets as described in that link but those are 67 pattern, not 68 pattern. These are 68's. http://67-72chevytrucks.com/vboard/s...=buddy+buckets
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-23-2008, 04:53 PM | #7 |
just an fyi, i've got a 68 small block high hump 2wd, 4 spd so there is another option
12-23-2008, 07:15 PM | #8 |
its all about the +6 inches
this is always confusing for some reason.
High hump floors came in; all 4 speed trucks, regardless of engine All 4X4 trucks, regardless of tranny All big block/TH400 trucks All other trucks, got low hump. There were a handfull of thucks that broke the last rule out of the factory, and then a handfull of trucks that should have had the low hump, that snuck out with a high hump.... but the rule from GM was as outlined above. |
12-24-2008, 02:26 AM | #9 |
Thats what I need to know, thanks.
