12-24-2008, 03:41 AM | #1 |
Stock Fan Clutch Info. Needed
Got a couple questions regarding stock fan clutches...
1. Did all our trucks come stock w/fan clutches...or maybe just AC trucks? 2. What diameter fan & how many blades is recommended for an AC truck w/stock shroud? I will be putting in a Vintage Air system and just realized that the fan I just sent to the powder-coaters is probably not gonna work....as it is a clutchless type.... Thanks in advance! Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
12-24-2008, 04:27 AM | #2 |
Gone to greener pastures
Re: Stock Fan Clutch Info. Needed
My '72 GMC, 402, with A/C has a clutch fan.
The fan is approximately 18" in diameter, with 6 blades, in a factory shroud. I'm afraid I can't do much better than that right now. It's dark, after midnight, I was reading the tape measure while holding a flashlight, & it's sprinkling (fortunately, not raining). If I can help you later on, after sunrise, just give me a holler & I'll go back & better look @ things for you.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-24-2008, 10:20 AM | #3 |
Old member
A/C trucks all came with the clutch fans. Mine is a 7 blade that measures 17.5" across from blade tip to tip.
Make sure the blades aren't bent at all or you will be buying water pumps on a regular bases.
12-24-2008, 10:32 AM | #4 |
I have one that might work for you...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-24-2008, 10:46 AM | #5 |
20' Daredevil (Ret)
My '72 w/factory air has a 7-blade fan.... iirc, it's about 18" diameter. I'll try to remember to check it after the sun comes up, if there's not too much snow on the hood...
