Old 01-06-2009, 08:56 PM   #1
hobsiscool
truck noise (video)
here's my truck idling...notice the smoke...what could be wrong? rockers?...smoke went away after it warmed up (it had been sitting a couple weeks)
hobsiscool is offline   Reply With Quote
Old 01-06-2009, 09:22 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: truck noise (video)
wow to me that idle sounds really high...
hows you choke doing?
that's my 2cents..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-06-2009, 09:26 PM   #3
hobsiscool
it is very high...it idles down once it warms up...i'm taking it in this weekend to get looked at by my uncle...he used to own a shop years ago and said he would check it out for me...just thought i would get some opinions.
Old 01-06-2009, 10:31 PM   #4
85mudder
85mudder's Avatar
sounds like a really fast ticking to me......possibly valvetrain is my guess!!
'04 Chevy Ext. cab SB 4WD 8.1 Allison Daily Driver
'84 Chevy 2wd 1 ton CCLB dually needs lots
'72 Chevy LBSC K20
85mudder is offline   Reply With Quote
Old 01-07-2009, 03:45 AM   #5
project 67 sub
project 67 sub's Avatar
yah thats what it sounds like to me to. probably loose rockers or something
project 67 sub is offline   Reply With Quote
Old 01-07-2009, 05:47 AM   #6
dammitmitchell
the pollock
i personally.. granted i do agree with the guys above
would start off with the simple stuff..
cleaned your carb lately?
tuned up lately?
OIL?
then i would start assuming the worst =-)
i dread assuming the worst first .. because it costs me mroe money and then my wife grounds me from NAPA...
waa!
Army vet 02-08
Old 01-07-2009, 12:02 PM   #7
hobsiscool
well my uncle seems to believe it's rocker noise from what I describe and from what he has heard on it...Hopefully they just need to be tightened or something easy like that...My only concern is the smoke...would this be a problem if the pushrods/rockers were loose, etc? Like I said this time it had been sitting, but it does smoke some even when it doesn't sit, but always goes away...is this just a symptom of an old vehicle...oil level is fine, maybe some lucas would help?
Old 01-07-2009, 12:42 PM   #8
87Bob
Smoke on start up that goes away can have several causes that I know of. One it could be actually steam from moisture in the the engine and exhaust system.
It could be oil that has seeped around the vavle stems and leaked in to the combustion chambers. Normally it is a blue puff at start up only.
Or it could be oil bypassing the rings that have lost some of their ability to seal untill you get some heat in the engine. Do you have to add oil often? Do you have to add coolant often? What color is the smoke? Does it do it when it is warm outside?
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 01-07-2009, 01:00 PM   #9
hobsiscool
I have only had this truck for one warm period and this is the first cold period...so as far as i know, no it does not smoke on startup when warm...since i have gotten it though, it has had the head rebuilt, transmission rebuilt, carb rebuilt, and converted to floor shifter instead of 3 on the tree....i also have had the oil pan gasket replaced...no longer leaking any oil there....i do have to add oil occasionally...have not noticed having to add any coolant...the smoke is a blue/white...i guess i would need to see them next to each other in order to distinguish clearly....i posted the video with the tailpipe smoking to show what it was doing...actually the head was rebuilt right before I obtained it, so I don't know what kind of a job was actually done as far as quality or exactly what was done...this truck was a red headed step child before it reached me so who knows...anyway...hopefully i can get it all sorted as I would like the build the 6 instead of replacing it...i think it would be a more unique engine to have.
Old 01-07-2009, 01:27 PM   #10
87Bob
Blue smoke is from oil white is from water. If the motor has lots of miles on it and it runs good I wouldn't worry about it. Keep an eye on your oil and water levels. When you get to the point that you're going to rebuild it then have it done right and you'll be fine.
Old 01-07-2009, 04:04 PM   #11
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If the heads have been rebuilt it shouldn't smoke on start up. That would be rings but it would do it all the time. Have you had anyone follow you watching the exhaust?
Did you get a list of the work done to the heads? Sounds like the valve lash is on the loose side.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-08-2009, 09:26 AM   #12
hobsiscool
No that's what I was saying...the head job was done right before I obtained it so I'm not real sure what all was done. The shop has since gone under (always a good sign) so I really don't know how to find out....eventually this engine will be rebuilt so as long as i can get it running good at this point i'm good to go.
Old 01-08-2009, 04:01 PM   #13
busman
blue smoke = fuel too rich, white smoke = oil
carb needs adjustment, leak down test on engine
check pcv valve for excessive oil = blow by = needs rings
just my $.02
busman is offline   Reply With Quote
Old 02-03-2009, 02:49 PM   #14
hobsiscool
Re: truck noise (video) **UPDATE**
So I got my truck to my uncle the other weekend, he got around to opening it up...turns out, I had about 3 rocker arms completely off track, and one bent push rod...3 arms were completely loose not do anygood, and probably at least another 2 were not adjusted properly...seems as if whomever replaced the head didn't adjust it one bit...my uncle is going to replace the pushrod, check for any more damage, adjust everything correctly, and then readjust the carb...hoping to run like a completely different truck when I get it back...he also lives next door to a body man/transmission expert...he's going to see if he maybe wants to trade my man trans for an auto...hate driving the stick in traffic!!
Old 02-03-2009, 04:27 PM   #15
babyJay
Arrived on a Pale Horse
babyJay's Avatar
just my $.02
White smoke is coolant, Heavy blue is oil, black or light blue smoke can be fuel too rich. That truck sounds like a sewing machine on stearoids. I'd venture to guess maybe a head gasket from what I can tell. Got milky oil in the crankcase?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 02-03-2009, 08:12 PM   #16
spudz
spudz's Avatar
if its cold outside, that smoke is just condensation in the exhuast.... Sounds like it may have a stuck lifter... put about a half a quart of ATF in the oil and change your oil in 500 miles... this will clean it out and loosen some crud up..
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-03-2009, 08:18 PM   #17
enaberif
Wow that sucker sounds like a singer sewing machine!
Definitely valve train noise.
enaberif is offline   Reply With Quote
