72 k10 4x4 front shaft
will the front shaft of a 77 blazer fit my 72 k10? if not what shaft will fit in my th350/205 transfer case?
Re: 72 k10 4x4 front shaft
Maybe. Probably not the answer you are looking for. You need to measure the two then you can make the decision.
#3 | |
Are you running any lift? How much? What style output on your 205? ![]() Last edited by Cyclone; 01-22-2009 at 09:43 PM. |
It should be around 29 inches
Here is the pic of the t/c side
Are those holes in the yoke threaded?
No they are no, Same as the axle side 2 threaded clamps with a 1/2 inch nut.
OK, the red one in my pic above will work then, I'll get a cost from UPS.
thanks C, pm me when you do
