Old 02-01-2009, 02:30 PM   #1
Green Machine
Green Machine's Avatar
WTB - TH400 Yoke
Looking for a Turbo 400 yoke for the larger seal, yoke should measuere about 1 7/8 in. in diameter. Let me know - Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-01-2009, 08:02 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: WTB - TH400 Yoke
Are you wanting one with outside clip u-joint or inside clip (C-clip)? (our trucks originally used outside clips) I have both.
$40.00 ea shipped
Livrat is offline   Reply With Quote
Old 02-01-2009, 08:51 PM   #3
Green Machine
I would prefer the usual outside clip style. How long is it from the ujoint center to the end ? Ujoint cup should be 1 1/16, 1310 style joint. Do you have a pic ? Thanks.
Old 02-01-2009, 09:26 PM   #4
Livrat
Member #1049
Livrat's Avatar
yes they are 1310 series with 1 1/16 caps.. I will measure length and snap you a picture tomorrow while at the shop.
Old 02-02-2009, 12:23 AM   #5
Green Machine
Thanks, just want to verify that it is for the large seal, should be a hair over 1 7/8 or 1.885. I've already bought one for the smaller seal, just want to be sure this time. Anybody need a yoke for a Th400 - 1 11/16 size ?
Old 02-02-2009, 10:24 PM   #6
Livrat
Member #1049
Livrat's Avatar
Here are pics of the two that I have for a large seal.. both have the same size u-joint cap.. There is also a picture of the small seal one for reference.. they all have the same size cap.. the two large seal ones are wider than the small seal one..
Old 02-02-2009, 10:25 PM   #7
Livrat
Member #1049
Livrat's Avatar
more pics
Old 02-02-2009, 11:30 PM   #8
Green Machine
Thanks, great pics and measurements. The diameter on the fat ones is right, but it looks like they use the 1320 joint ? Maybe I'm looking for hens teeth, but isn't there a large seal yoke for the smaller joint ?
Old 02-03-2009, 12:02 AM   #9
Livrat
Member #1049
Livrat's Avatar
Your welcome!!
All of my T400 large seal yokes are the wider 1330 u-joint with 1 1/16" diameter caps or GM 3R. (inside clip) with 1 1/8"th caps
I did find this place that lists a T400 with 1310 u-joints...
http://www.dennysdriveshaft.com/c75_general_motors.html
Old 02-03-2009, 12:47 AM   #10
Green Machine
Yeah, I meant 1330, not 1320. Anyway, thanks for the link, kind of spendy, but new may the easiest way to get it done. Thanks for your help !
