Front Brake Hoses
I'm trying to find a source for the factory front brake hoses for a 63 4x4 with the drum brakes. I included a picture, most part vendors show the larger hose end for that year of truck, have any of you found a source for the correct hose, thanks, Larry
Re: Front Brake Hoses
I got mine from Napa. They worked / fit fine. Price seemed right too. If I recall it was Raybestos hoses.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
The larger one are the ones that NAPA gave me they won't even fit the wheel cylinders that they had, they had nothing else to offer. If you have a part number I would appreciate it, Larry
Hey Larry, I just finished swapping out the axles on mine but I think we saved the hoses. I will take a look in the shop tomorrow and let you know. Chris
Great, I appreciate it, Larry
I've mainly used my local Hydraulic hose guy..."Hosepower USA".....They had a complete brake fitting dep't......So I simply had them make me up custom hoses....$70 for the both fronts...
One other time they did not have the correct fitting for a hose I needed so they "re-captured" the fitting off of my existing hose....worked perfect and they even polished it up to look like new....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 02-11-2009 at 03:14 AM. |
Thanks Rack man, I have used the farm hydralic store for PS hoses, I'll look around, thanks again, Larry
Do you want factory replacement hoses or are you interested in braided stainless steel hoses?
Mick |
Hey Larry, I just got in from the shop. I did look for them but it appears they got tossed. I did get them at the local Napa though. Sorry, Chris
Thanks for looking Chris, Mick, I just want some newer hoses so they work well and are safe, braided steel are fine with me, Larry
A couple of adapters from the frame brake line (pictured)
And a couple of adapters at the brake drum, I don't have a picture, but an easy find, either 3/8 to -3 or 7/16 to -3 male. Then Smileys in Texas for the -3 braided brake line. Measure the length you need and make phone call. Mick |
Great info, I'll do that, thanks all for the help, Larry
#13 | |
Bloo
have you checked rockauto.com? they have some "oddball" stuff
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#14 |
I had not heard of them I'll give them a look as well, thanks, Larry
#15 |
#16 | |
Bloo
i checked, the higher end grade at rockauto, is around $30 each. it is part number bh34466
#17 |
Thanks guys I'll check them out at Rockauto, thanks again, Larry
