Old 02-13-2009, 12:14 AM   #1
og350
og350's Avatar
99-05 bucket seats
i got a set of 2005 silverado seats with the flip down center for cheap from a friend at the junk yard. I am wondering if anyone has pictures of them installed or mounting advice on putting them into a 71 with a stock bench. thanks!!
og350 is offline   Reply With Quote
Old 02-17-2009, 09:01 PM   #2
og350
og350's Avatar
Re: 99-05 bucket seats
i know someone has to have some of these!
Old 02-17-2009, 09:03 PM   #3
jbristo67
resident oilfield trash
jbristo67's Avatar
I want some does that count.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-17-2009, 09:08 PM   #4
og350
og350's Avatar
well its a good start! it was hard to find a good set with the flip down center seat!
Old 02-17-2009, 11:25 PM   #5
tk-mpl
tk-mpl's Avatar
I would show you mine, but not completely done yet. I just made some 2.5"x4" plates up and will weld them to the floor to made it stronger around eack bolt hole.. For fitment I just made a plywood template of the base and drilled holes. They fit pretty good. Going to have to shorten the steering column though.
tk-mpl is offline   Reply With Quote
Old 02-18-2009, 12:14 AM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
There are some pic of my 2005 seats installed and the fabricated mounts under the cab. Is this what you are looking for?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-18-2009, 10:05 AM   #7
project1971
project1971's Avatar
fantastic! i have a set waiting to go in and was wonders how easy it was going to be. that doesn't look bad at all.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 02-23-2009, 10:50 PM   #8
og350
og350's Avatar
that is perfect!! thanks for posting that for me.i hope to get to installing my set soon!!
Old 02-23-2009, 11:20 PM   #9
Ackattack
Ackattack's Avatar
yep, not too bad. Just make sure that you make some plates to go on the bottom of the cab.
I think I got some Grade 8 7/16" bolts to mount mine up.
Ackattack is offline   Reply With Quote
Old 02-25-2009, 01:04 AM   #10
og350
og350's Avatar
do these seats take up alot of cab room with the stock gas tank still in the cab?
Old 02-25-2009, 03:27 AM   #11
rambler
MOVE OVER
rambler's Avatar
I think most people pull the cab tanks and put one under the bed for these seats... or you will be hugging the steering wheel.
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 02-25-2009, 06:05 PM   #12
jamieg
i was thinking about doing this as well. I would also like to see more pics of this and what reinforcements would/should be adequate.
I have heard also that this year of seat leaves a little to be desired for legroom as the seat is a bit thick.
I have been looking at new 09 seats and they seem a lot thinner, and i would just buy factory shoulder harness for a seatbelt to minimize extra work for seat reinforcment.
any more info?
jamieg is offline   Reply With Quote
Old 02-25-2009, 09:02 PM   #13
jugernot
Life, Be In It.....
jugernot's Avatar
The only warning I have to say is that if you are a tall person you might not have alot of head room. I'm 5'8 and fit perfectly, but feel like I'm sitting tall inside.
