Old 02-19-2009, 12:35 PM   #1
19gmc67
19gmc67's Avatar
Question tire and wheel question
is there any way to repair tire beads from leaking.the tire on my truck were flat from sitting in one spot for a while ,got them aired up and they started leaking from around the beads.is there anyway to fix it .btw the tires are still good.
19gmc67 is offline   Reply With Quote
Old 02-19-2009, 12:38 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: tire and wheel question
You may have to remove the tire from the wheel. Wire brush or sandblast the bead. Prime/paint them. If there are pits lleft behind, use bead sealer. Initially pump the tires up to 40 psi to seat the bead good. Then lower it back down to the recommended pressure. You should be good to go.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-19-2009, 12:41 PM   #3
19gmc67
19gmc67's Avatar
thank you
Old 02-19-2009, 02:30 PM   #4
drewdude92
72 chevys 4 life
drewdude92's Avatar
yeah at the shop i work at we just bust them down and put some bead sealer junk on em it works everytime. or you can just hit with a large hammer right on the sidewall where they are leaking. but not too hard
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
