Old 02-23-2009, 11:12 PM   #1
cecilio
cecilio's Avatar
How to install front fender seals
I purchased a set of front fender to cab seals for my 69 pick up, but there wasn`t any instrcutions about how to install them, I need some manual or instructions to install
This is the description from supplier (Classic Parts)
67-72Die-stamped rubber seals that fit between the rear edge of the front fender & cab. Originally used on deluxe pickups only.
cecilio is offline   Reply With Quote
Old 02-24-2009, 12:43 AM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: How to install front fender seals
Attached are two pictures of the driver's side which I borrowed off the board. IIRC they are stapled to a sheet metal piece which is screwed to the cab.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 02-24-2009, 07:02 AM   #3
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
ttt.... "Subscribed" I will be doing this in the near future.....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 02-24-2009, 08:32 AM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
How many ppl run these, and what year did they start installing those? I have them on the '72 parts truck but not the '67
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-24-2009, 12:22 PM   #5
Tim Christian
Tim Christian's Avatar
I have only found the metal plates the seals attach to on 71-72 Trucks only and not all of them. But you must have the plates to mount the seals.
Tim Christian is offline   Reply With Quote
Old 02-24-2009, 12:46 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
I recently pulled mine off of my 72 Blazer. They have the metal pieces as well. I am assuming they are fully original and in the factory location but I can't swear to it. Sorry the pictures were taken more to show the rust.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-24-2009, 01:58 PM   #7
Gillnetter
Gillnetter's Avatar
Who sells these fender seals?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 02-24-2009, 02:34 PM   #8
Bruce88
Bruce88's Avatar
Hears a scan of the factory drawing that was used by the factory for assembly from (1967-1972 CHEV/GMC Truck Factory Assembly Instruction Manual) maybe this will help you. When this option was first used I do not know but this drawing shows it modified a previous seal installation on 9-8-70. So if I had to guess when this option was available I would say 1970 to 1972.
I would defiantly recommend this book to any one that wants to see what the factory did for installing the parts and wiring. The only drawback is the book does not have an index to find what you are looking for or modification made during the years. You just have to go thru it page by page to find what you need. Wes (a site vendor) at Classic Heartbeat has the book, he lists it as (67-72 Factory Assembly Manual) http://www.classicheartbeat.com/books,_vidio,_cds.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 02-24-2009, 03:21 PM   #9
71 super
71 super's Avatar
the seals were generally found on upper optioned cabs, so most do not have them, and is a good way to tell if truck is original cheyenne etc. they are pieces not repoped but most don't know they exist.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-24-2009, 04:48 PM   #10
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Subscribed....Me too.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-24-2009, 05:39 PM   #11
cparman
sharp as a marble
OK, I do not want to be a silent idiot. What to these seals do? I have been aware of them before, but just wonder are they for noise or dirt?
cparman is offline   Reply With Quote
Old 02-24-2009, 08:26 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
Both
I have mainly seen these seals on Cheyenne/ Sierra trucks, not the lower end trucks. I just parted a 71 Cheyenne tha had hem i kept the sheetmetal pieces since they are not being reproed as far as I know.
WIDESIDE72 is offline   Reply With Quote
Old 02-24-2009, 08:41 PM   #13
71 super
71 super's Avatar
On trucks without- especially with clutch fan there is actually blow through -for lack of a better term- that is felt into the cab from the engine compartment. These seals prevent that from happening as well as the dirt/debris issue. I think that the seals may have been part of the comfort/convience option like the under dash insulation found in the higher end trucks. All adds to the reduction of noise and increases the comfort level- aiding in the move from utilitarian to the modern comfort these trucks helped Chevy move toward. They require the special brackets as stated earlier that are not repoped. The seals come with thick/heavy staples that hold them onto the sheet metal bracket. I jave yet to be able to use the staples that are sent with these and instead use a heavy insulation staple from Lowes. They require 14 or so staples per bracket and I install them by inserting and then bending with a punch. You must have the brackets for the seals to install correctly and there is a specific bracket for each side. They simply install with a couple of screws into the cowl region as pictured in the build manual schematic. Hardest part are the staples.
Old 02-24-2009, 08:46 PM   #14
OhNoJoe
OhNoJoe's Avatar
Here is a pic from LMC
http://www.lmctruck.com/icatalog/cb/full.aspx?page=13
OhNoJoe is offline   Reply With Quote
Old 02-25-2009, 07:25 PM   #15
cecilio
cecilio's Avatar
Thank you so much for your explanation 71 Super
Old 02-25-2009, 07:29 PM   #16
cecilio
cecilio's Avatar
I purchase the seals at Classic Parts
Old 02-26-2009, 12:13 AM   #17
OhNoJoe
OhNoJoe's Avatar
Any one got a drawning of the the special brackets that are not repoped. Maybe someone can mock one up?
Old 02-26-2009, 06:36 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
I have a set of the brackets, but trying to do a drawing is easier said than done. If you take a look at the drawing from the Chevy assembly manual that was posted above, i think you will see what I mean.
Old 02-26-2009, 10:36 AM   #19
Hutch
Hutch's Avatar
There was a member on here a couple years ago that was making the metal brackets up and trying to sell them.
He did not get many takers at the time.
I can't remember his name but he did show picture of his product.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-26-2009, 11:44 AM   #20
truckintexas
Attachment 434331
The title of the drawing is 1971 TRUCK "C-K" SERIES 3975764
with an original date of 4-4-70 and a revision of 9-8-70.
I think 1971 was the first year for the seals.
truckintexas is offline   Reply With Quote
Old 02-26-2009, 11:47 AM   #21
HuggerCST
HuggerCST's Avatar
It must have been '70, because my '70 CST has them.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-26-2009, 02:53 PM   #22
PHAT TONY
PHAT TONY's Avatar
My experience with re-pop seals and factory brackets 3 times now has been a lesson in frustration right up to the dissapointing final fit. (I prolly threw a fit too!)
PHAT TONY is offline   Reply With Quote
Old 03-03-2009, 08:28 AM   #23
petey-pablo
"THE GREEN GOBLIN"
After inspecting a simular bracket that was in a parts box that came along with the truck I think I have a winner always wondered if it even belonged to the truck
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 03-06-2009, 01:16 AM   #24
badpeanut
badpeanut's Avatar
Here are some more pictures: http://67-72chevytrucks.com/vboard/s...ghlight=fender
'70 GMC LWB trailer
Old 12-03-2020, 05:28 PM   #25
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Hoping someone can help with the fasteners.
1. How many fasteners are there actually, per side?
2. Are they all the same size?
3. What are the "spacers" exactly?
I got from a forum member (Jeff's bowtie's) the seal/bracket and I think some/most of the screws are present but no spacers. I'll be replacing the rubber part for sure (the existing rubber gives me a great guide how to deal with the staples).
The assembly page in a few posts back mostly confusing me where/what/how the screws are used. Perhaps the two screws listed as [2] with a [3] has spacers, then anything with a [A] means the same screw but no spacer?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
