Old 03-03-2009, 05:26 PM   #1
Redline
Redline's Avatar
3/4Ton Dually????
Has anyone ever hear of a 3/4 ton 1963 dually??? The frame vin and cab vin match. Thanks to everyone who helped me find that.... The rear end and every thing appears to be original, but I have never seen a dually on a 3/4ton....
Redline is offline   Reply With Quote
Old 03-03-2009, 06:54 PM   #2
kizer
Its Deja Vu time again
kizer's Avatar
Re: 3/4Ton Dually????
Is there any markings on the rear end?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-03-2009, 07:03 PM   #3
Redline
Redline's Avatar
Still cleaning off years and years of grease.....I should have a number by this evening... The older gentleman I bought it from said his dad bought it new like that. They used it to move cars around with at there tow lot....
Old 03-03-2009, 08:23 PM   #4
Redline
Redline's Avatar
Dually Rear end
I finally found the the number on the rear end.... 393463 From the info I can get its a Eaton.... Does this sound right???
Old 03-03-2009, 09:24 PM   #5
Redline
Redline's Avatar
Got it..... I think its an Eaton, not sure though 393463
Old 03-03-2009, 11:56 PM   #6
Rogue
Airport Bum
Does it have offset wheels front and rear?
I have seen tons of 3/4 tons with 1 ton rearend retrofitted.
Standard wheels front and offset rears.
also JC Whitney used to sell adaptors to add standard offset duals.
Those are scary IMHO
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 03-04-2009, 01:37 AM   #7
Captainfab
60-66 Nut
Re: Dually Rear end
From what I could see in your pics, yes it is an Eaton HO52 or 72
Old 03-04-2009, 09:20 AM   #8
Redline
Redline's Avatar
Re: Dually Rear end
How do I figure out which one it is??? I looked online and couldn't find a manual.
Old 03-04-2009, 09:42 AM   #9
Redline
Redline's Avatar
By offset do you mean does it use the same wheel? If so yes it is the same wheel just faced together
Old 03-04-2009, 10:26 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
If there are 10 bolts in the cover flange, it is the HO 72 differential. The question about the wheels is are the same wheels used front and rear? The wheels for the 3/4 tone have a shallower setback. If the wheels are no the same, you have a truck that someone swapped the differential on.
While the dual wheels were not an option for the 3/4 ton, it is possible that either the dealer made the swap or the dealer had enough clout to have the factory put on the duals.
Since there are no records that have survived, this is one mystery that will remain unsolved.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-04-2009, 01:14 PM   #11
Redline
Redline's Avatar
Yes they are the same exact wheel. Thanks for all the information!! At least now I know what I have so I can start building her back up. How are those HO 72 differentials???
Old 03-04-2009, 02:24 PM   #12
Rogue
Airport Bum
Would a 1 ton have trailing arm/coils?
CRS is kicking in.
1964 Chevrolet C-10
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Old 03-04-2009, 02:39 PM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
The HO 52/72 is a good, reliable full-floater differential. They are not bulletproof by any means. Biggest problem is gearing. Not many selections. Available are 4.10, 4.56, and 5.14 (or so). So if you want better gears swapping to a 14 bolt is needed. The 10 bolt was dropped in 1972.
Fred
Old 03-04-2009, 04:13 PM   #14
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Look in the back ground.
Is that a C20/30?
Joey~AP is offline   Reply With Quote
Old 03-04-2009, 04:44 PM   #15
Redline
Redline's Avatar
Not sure but I like it!!! Great photo
Old 03-04-2009, 08:49 PM   #16
factorystock
factorystock's Avatar
Redline, Yes your truck is original. Chevy did offer a dual wheel option on C20 3/4 ton chassis cabs and stake models. Your vin should start C2503 for chassis cab or C2509 for stake bed.No mystery Fred. The 4.57 can be swapped out with a 4.10 from a pre 72 C 20, then I would go with a set of pre 1970 8-19.5 duals which can be found. This will be good for 65 mph with no welding or fabricating and still be period orginal.
factorystock is offline   Reply With Quote
