Trailing arm bushing
I am about to replace the trialing arm bushings in my '69. Is there an easy way to get them out?
Under Construction
Re: Trailing arm bushing
I have used a c-clamp with a socket to push em out, i also recently used a balljoint tool to remove/replace. I have heard of ppl burning the rubber out with a propane torch etc. good luck with your approach...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Moderator
![]() Join Date: May 2007
Torch 'em!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Never Ending Projects
Press works great.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Mar 2007
I torched mine. Hold the torch on it till the rubber oozes out.
sharp as a marble
![]() Join Date: Jan 2007
They come out fairly easy, with an air chisel. I just replaced mine, and used and air chisel, and vibrated them out. With the arms on my bench, I was done in less than thirty minutes. I bought a set of used arms from a board member, and knocked out the old bushings before they went to the powdercoater. When I got them back I set them on the bench, and used a large socket that would set on the outside shoulder of the bushings, and a BFH and away we go
Watch out for your cornhole !
![]() Join Date: Jun 2003
15 seconds in the press. No smoke, no drippy rubber.
Six in a row makes it go...
![]() Join Date: Mar 2009
I heated them slightly with a heat gun and then pressed a socket through and everything came out.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
yea the smoke is pretty nasty and i'm sure its not good for you. Best to do in the open air. Make sure your dog is in the house, mine likes to stay close to me and I was afraid she would step on the hot rubber.ooouuuch
