Old 05-15-2009, 10:48 AM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
327 into a 383 stroker
what all do i need to do this? i have a guy that will install everything with me (im not expierienced). how much, what do you reccomend?
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-15-2009, 10:55 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: 327 into a 383 stroker
I am sure that you will get good info here, but A simple google search turned up 24,000 results...
http://www.google.com/search?hl=en&q...roker&aq=f&oq=
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-15-2009, 11:13 AM   #3
ZombieWeinerDog
looking for a list of parts needed
1972 longbed- 454
1967 shortbed- 355
Old 05-15-2009, 11:20 AM   #4
haysonj
haysonj's Avatar
You can buy the kit from Jegs or any performance outlet, then you will need some machine work to clearance the block and bore for the new pistons. Personally I would look for a 350 truck block in a wreaking yard.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-15-2009, 11:26 AM   #5
ZombieWeinerDog
isnt the 327 block the same as a 350 block?
1972 longbed- 454
1967 shortbed- 355
Old 05-15-2009, 11:39 AM   #6
haysonj
haysonj's Avatar
No it depends if you have the early 327 or late one . I'm sure it can be done but if you have the early block it will take a special crank shaft and more machine work. I built mine from a 350 and the cost was almost as much as buying one from jegs. You also need to have a machinist that has a good balancing machine as the stroked crank is harder to balance.
Old 05-15-2009, 11:40 AM   #7
ZombieWeinerDog
well, i have a 327 from 1967, i also have a newer 350 block from a boat
1972 longbed- 454
1967 shortbed- 355
Old 05-15-2009, 12:17 PM   #8
haysonj
haysonj's Avatar
your 327 is the small journal crank shaft and I personally would not use it for a 383. the 350 should be fine. You need to find a good machinist and talk to him about what you want to do.
Old 05-15-2009, 11:03 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'd be $$ ahead to get a later model roller 350. Even when you add the zink to the oil, flat tappet cams just don't last (or make the power) that a roller cam does.
You can sell the old stuff to get back the money you'll spend on the late model engine.
Old 05-16-2009, 06:24 AM   #10
jim zag
ENGINE BUILDER
jim zag's Avatar
This is easy, large journal block, buy a balanced assembly, make sure the rod bolts clear the block, 9-9.5 compression, not too much cam, nice intake and carb and stand on the GAS!!!!!
JIM ZAG
jim zag is offline   Reply With Quote
Old 05-16-2009, 02:40 PM   #11
First of all,you don`t get 383 out of a 400 crank in a 327.A 383 is from a 400 crank in a 350.See?
Old 05-16-2009, 05:11 PM   #12
haysonj
haysonj's Avatar
the 327 and 350 have the same bore so if you go .030 over with a 3.75 stroke you get 4.030 x4.030 x.7854 x 3.75 (400 crank stroke) x 8 =382.6681 or 383
Old 05-16-2009, 10:41 PM   #13
capev86
a 305 engine can be used if a 350 is not available.
i'd take a 305 with a stroker crank and not worry about the bigger pistons found in the 350. fuel injection and a low rpm camshft
in a truck, efficient air flow and gobs of torque are what counts. if you keep the standard 350 bore, you get a 377 with the stroker (400) crank.
i have a 406 (400 bored .03) that will replace the 307 in my 72 burb 2wd 3/4 ton. will have to find something more highway friendly than the 4.57 rear gear when i do the swap. but for now i need the gearing for towing duties. shows how much low end torque makes driving a pleasure.
capev86 is offline   Reply With Quote
Old 05-17-2009, 07:10 AM   #14
You`re right/I`m confused.i have a hard time keeping this stuff strait in my head.We were just talking about all these combinations on friday at my friend`s machine shop,too.
Old 05-17-2009, 07:25 AM   #15
ChaseDale3and8
ChaseDale3and8's Avatar
I wouldn't even bother with doing a stroker kit on a 305. You'd be way ahead just doing a stock stroke 350 rather than stroking a 305 since the stock 350 will have more cubes than a stroked 305. (334 cubic inches) Even though the 305 and 350 share the same main journal size it still requires special pistons and the same machine work as turning a 350 into a 383. Just my 2 cents. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 05-17-2009, 10:38 AM   #16
Longhorn Man
a 305 has such small bores that it is hard to get air in them, and you are limited to smaller valves further limiting it's air intake.
I'd run a 307 before a 305. The only thing a 305 is good for is putting it's later model heads on an early 287/307
Old 05-17-2009, 12:05 PM   #17
68c10owner
68c10owner's Avatar
speed o motive use to sell a small journal stroker kit. I would look for a 350 block insted though like everyone else has said.
Anthony
68c10owner is offline   Reply With Quote
Old 05-17-2009, 12:41 PM   #18
bac1755
bac1755's Avatar
Does your 327 look like this? This is looking at the rear of the engine where the distributor goes, the red circle is distributor the yellow is what your looking for. If it does not have what is in yellow you have a large journal 327 with a 4" bore, just like the 350. they only have different cranks.
1971 GMC
1972 Small Blocked DATSUN 240Z Dads old car
bac1755 is offline   Reply With Quote
Old 05-17-2009, 03:56 PM   #19
'72customdeluxe
You might come out ahead getting something like this http://cgi.ebay.com/ebaymotors/SBC-3...spagenameZWDVW
instead of rebuilding, forged pistons, more compression for 1500
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
