Old 05-19-2009, 09:07 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
rebuild front drums or start to disc..
i started to rebuild my drums and gotta new mc....well i spend 2 hrs on 1 hub, and didnt even finish it!!!!!!!!! (i got the mc on in those 2 hrs also) but im thinking id be money ahead to swap out to disc since i already have most everything i'll need...(i gotta whole disk truck to steal parts from)
so should i rebuild my drums for now (already got the parts)
or should i take the spindles off my 72 and put on 68 and go front disc?
and tomorow is MY last day of school, so i have all summer to figure it out, but would like to get done by saturday night (car show on the mtn)
but idk if i get done that soon (gotta get lots of hay put up)
so what should i do and thanks
John
1999 Toyota Tacoma 4x4
Old 05-19-2009, 09:09 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: rebuild front drums or start to disc..
start a disc swap, you won't regret it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-19-2009, 09:33 PM   #3
oldblue1968chevy
are discs easier to work on...cause all them sprins in my drums are a pita
wat i think ima do is go disc 5 lug in my front and stay 6 lug in rear for awhile..
so outside of balljoints and tierod stuff the 71-72 spindle stuff will work?
what should i replace, can i use the old brake lines,bearings, pads?
and can somebody tell me what tie rods and balljoints i'll need
John
Old 05-19-2009, 09:39 PM   #4
mvfd70
mvfd70's Avatar
Discs are much easier to work on. No return springs like drums.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 05-19-2009, 09:43 PM   #5
oldblue1968chevy
i hate those blasted springs lol
okay, will the 71 72 balljoints press into my a arms, or will they be the wrong size? and ima wing it on the tie rods lol, rite now i just wanna get the spindle on there correctly and get em workin lol
i need from autozone
72 chevy brakelines (?just the rubber ones?)
72chevy brakepads
72chevy balljoints (ALL)
and what else? thanks
John
Old 05-19-2009, 10:16 PM   #6
Elephanthead
If you only need to stop hard once, drums are better. The master cylinders are different, discs need more volume of fluid to stop, I think you may need another new master of you switch. I would finish the drums since you already have the parts, unless your planning on auto crossing this truck. The fronts are easy, no parking brake.
Elephanthead is offline   Reply With Quote
Old 05-19-2009, 11:00 PM   #7
chev-obsession
chev-obsession's Avatar
im doing one on mine currently. i got my parts off of a suburban, dont get suburban parts!!!! but i would get new pads, calipers, bearings, balljoints and any other thing that might possibly be worn out. i got my brake lines from this place called "right stuff" i didnt really like them, they were a real pain to get in, i think they could fit a little better. the upper and lower ball joints (for a truck) fit right in. you will need the ball joints and tie rods for a 71 or 72, whatever your parts truck is.
Good Luck!!!
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-19-2009, 11:02 PM   #8
chev-obsession
oh yeah. btw you will want the master cylinder and power brake booster if it has one and the brackets too. and take lots of pics of the parts truck.
1965 c/10 swb
1969 c/10 lwb
Old 05-19-2009, 11:44 PM   #9
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
just redid all my drums new MC and lines. Stops pretty good to me and the one time i locked em up and left 40ft of tire marks discs are nice I say gather parts save up and get ready to do it all at once if your gonna do a disk swap. since tmw is your last day of school you've got all summer. Just doing your drums now will get you back on the road quick and then when you have the time and parts do the disk swap
mikajo39 is offline   Reply With Quote
Old 05-19-2009, 11:47 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats like asking should a keep the 8 track or go for a CD player.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-19-2009, 11:53 PM   #11
mikajo39
mikajo39's Avatar
idk man i dig the 8 track
Old 05-20-2009, 08:16 AM   #12
oldblue1968chevy
well ive got all the 'USED' parts already need to buy a few other parts i'll swap over here in the next week, its on jakcsstands now but hopefully will be done later
John
Old 05-20-2009, 08:45 AM   #13
cdowns
cdowns's Avatar
you should get new bearings you'll need different brake lines both hard and soft as well as mounting tabs on crossmember a different master cylinder and combination valve for the disc setup
i'd spend a day doing the drums and getting them finished and truck on road// you may be able to get the disc conversion done before you start school in the fall
Old 05-20-2009, 05:41 PM   #14
oldblue1968chevy
well im nearly commited to the disc swap now im pullin em off lol
what are the 'mounting tabs on the crossmemeber'???
i need hard lines huh...should i get prebent ones? or bend them myself or what, or could i use the old ones from the 71?
John
Old 05-20-2009, 06:18 PM   #15
cdowns
cdowns's Avatar
it would be alot less work to just unbolt the crossmembers and switch in the complete 71 crossmember and suspension and brakes// it's less than 20 bolts total to getr the job done
Old 05-20-2009, 08:17 PM   #16
oldblue1968chevy
well, too late lol probably would have been easier
what ima replace
rotors there worn good
pads
soft brake lines (autozone can only get the pass. side, were can i get other side??)
balljoints (all)
and ima try to reuse my 72 mc and proportinong valve and the hard lines....
will have about 250 plus my time (thats alot of time lol) in the job, all ive got done so far is gotten the 72 calipers rotors spindle off so far...tomorow after hay gets in ima take my drums off and go to town in gmaws accord lol
do i sound like im on the right track or is something wrong? if im doin something wrong correct me please and thank ya
John
Old 05-20-2009, 08:30 PM   #17
jbristo67
resident oilfield trash
jbristo67's Avatar
Why wouldnt you just go ahead and swap the rears too. You are talking an extra couple of hours and you are good yo go
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-21-2009, 09:36 AM   #18
oldblue1968chevy
i am....
should i leave it 6 lug drums or find a 5 lug rearend...
John
Old 05-21-2009, 11:28 AM   #19
oldblue1968chevy
okay you guys said i need to swap to 71-72 hardlines right?
so do i need front AND back hardlines
or just FRONT hardlines
'please say front' please say front please say front lol
this is starting to be bigger than i thought lol
John
Old 05-21-2009, 12:29 PM   #20
cdowns
cdowns's Avatar
just fronts are different
Old 05-21-2009, 12:30 PM   #21
oldblue1968chevy
cool!!! yess!!! lol
so can i reuse my 'used' hard lines...and autozone can only order the passenger side soft b. line...where can i get drivers side?
John
Old 05-22-2009, 08:16 PM   #22
oldblue1968chevy
okay....bougth just about everything i need except the tierod ends and the soft brake lines today...
i cant for the life of me get my spindle separated from my balljoints ive tried the separator tool, wackin it, soaked it in wd40 wacked some more lol....is there any good way to separate them (this is on my blue 68 with drums)
and what year tierod ends do i need to get?? thanks!
John
Old 05-22-2009, 10:16 PM   #23
oldblue1968chevy
anybody got any ideas?..
John
Old 05-23-2009, 12:01 AM   #24
jbristo67
jbristo67's Avatar
cool!!! Yess!!! Lol
so can i reuse my 'used' hard lines...and autozone can only order the passenger side soft b. Line...where can i get drivers side?
napa You need to hit the knuckles as hard as you can with about a 3 pound hammer. 3 to 10 licks and they will bust loose. Just make sure you loosen the nut off but leave it on or you might need to go to the dentist
2011 Nissan Armada
Old 05-23-2009, 07:48 AM   #25
oldblue1968chevy
im hitting right besides the bumpstops wihh a 5lb sledge lol bout 5 likcs and i gotta take a breather lol
John
