Old 06-05-2009, 07:39 PM   #1
fdbdw
fdbdw's Avatar
Intake ports
installing a performer eps manifold and eld 1406 carb, 71 c10, 350,hei
There is a port on the manifold and on the heads, in between the two center bolts the gasket has that port coverd up and I thought I might need to cut it out. Talked to someone that told me that those center ports are for Q-jets application and not needed for my application, he said to just covet the ports with the gasket. Can anyone confirm this info and maybe give some education to me on it, thank you
fdbdw is offline   Reply With Quote
Old 06-05-2009, 08:00 PM   #2
cdowns
cdowns's Avatar
Re: Intake ports
i think your talking about the heat crossover// for performance leave blocked,winter use in cold weather climates it aids in driveability
Old 06-05-2009, 08:12 PM   #3
fdbdw
fdbdw's Avatar
Re: Intake ports
ya heat crossover, i couldnt remember what it was called, thanks , can you school me in it, I realize Im not gonna use it but just like to know more
Old 06-05-2009, 08:46 PM   #4
cdowns
cdowns's Avatar
Re: Intake ports
heat goes from one head to the other heating bottom of the manifold to heat the gas mixture ,less time on choke better drivability at some loss of power// blocked off it gives you a denser fuel charge and more raw horsepower but with a loss of smoothness that a heated charge gives you// a somewhat happier comprimise instead of full open gaskets is 3/8holes in gasket allowing partial flow thru the riser
Old 06-06-2009, 07:49 AM   #5
fdbdw
fdbdw's Avatar
Re: Intake ports
perfact sense thank you
Old 06-06-2009, 11:04 AM   #6
sjarrett71
sjarrett71's Avatar
Re: Intake ports
Every time I've replaced an intake or gaskets I just use the recommendation from the gasket manufacturer. I believe there should be a flier in the box or something.
-Scott-
sjarrett71 is offline   Reply With Quote
