Old 05-17-2002, 08:59 AM   #1
dubie
dubie's Avatar
Post Steering box question
Can I use my manual steering box when i switch to power steering ? Wasn't sure if there were a couple plugs to remove for the lines or not. Probably need to buy a used P/S box to match right?
currently
1972 Long fleetside
250, inline 6 with 3 speed manual
Soon to have
a freshened up 350
staying with the 3 spd
new rally wheels
fresh paint
custom flatbed with stacks!!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-17-2002, 09:11 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Talking
No, and you can't put a shifter knob on that has a 5th gear painted on and expect to have 5 gears :-) (reality check)
The Manual box is smaller. I would go to a junkyard and get the whole setup. Pump, bracket, Hoses, Steering box, pitman, and you will probably need the rubber flex disc or rag joint that goes between the box and the steering shaft as the one on a power system is bigger.
Good Luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 05-18-2002, 01:29 PM   #3
JW
Post
I replaced my 72 power steering box with a 76 unit. The 76 did have the pitman arm already on it. I used all of the 72 steering column parts. I used the 72 power steering pump and lines. Everything bolted together as if I was using the 72 power steering box. Alignment, as per standard sepcs, drives without any problems. I did add a steering stabilizer unit.
I tried to use a 73-86 power steering pump, this would not work, as the mounting bracket is different than the 72. Also, I would check the pully's on the crankshaft to be sure there is a pully for the additional belt, and correct pully alignment, for the power steering pump. Have no idea for the steering column shaft, could be a possible difference in lenght ?
72 Cheyenne Super, Fleetside, Shortbed,
Original Owner, Special Ordered
350ci/340hp, Auto Trans, 3:70 Posi, Tow Package
Northern Calif
Northern Calif
JW is offline   Reply With Quote
Old 05-18-2002, 01:53 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Post
Yep you need a ps box.
Toms River NJ
(Transplanted Hoosier)
56 working Street Rod(under construction 71-2 coil chassis)
Give a man a fish and he will eat for a day. Teach him how to fish and he will sit in a boat & drink beer all day.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
