Old 06-23-2009, 03:15 PM   #1
Molyorange
Front suspension
I have another question about my 64, I was given a 75 C10 LWB and I want to know if the control arms can be installed on my 64. I want the 5 lug pattern and power brakes.
Molyorange is offline   Reply With Quote
Old 06-23-2009, 06:56 PM   #2
apachedaddy
apachedaddy's Avatar
Re: Front suspension
Yes it will all fit, there use to be a sticky about this but it seems to be gone. do a search and you will find a couple of threads on this subject.
apachedaddy is offline   Reply With Quote
Old 06-23-2009, 11:24 PM   #3
Captainfab
60-66 Nut
Yes it will all work....suspension, steering box, master cylinder, prop valve, etc.
If you don't want to switch the whole crossmember, and just switch the control arms and the rest, I would suggest drilling out the holes in the original crossmember so you can use the larger U-bolts from the '75.
Old 06-24-2009, 08:51 AM   #4
Molyorange
Thanks guys. I also was reading the article about 2.5 and 3 inch spindles, I gather that if you run 15s the 2.5 spindle clears the wheels. I had that problem on my 89 C1500 with spindles rubbing the stock aluminum wheels. I appreciate the info...I will run the stock steelies till I can get the BIG WHEELS.
Old 06-24-2009, 08:59 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
75 Suspension bolted up to the 65 cross member with 75 steering componants. 3" drop spindles with 15" wheels.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-24-2009, 09:15 AM   #6
Molyorange
Thanks for the pics. Did you use one of CaptainFabs Power steering Brackets?
Old 06-24-2009, 10:02 AM   #7
Chevy Fleetside
I used this one. http://www.classicparts.com/1960-66-...ctinfo/76-979/
Old 06-24-2009, 09:34 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used the same bracket as he did. Bought it same place too. It's a REZ Engineering kit and it is very high quality. I like it because it uses an inner frame plate as well as the outer one.
