06-25-2009, 05:09 PM | #1 |
Xmember Fab Question
Hey Everyone,
Man, there is ton of great info on this site I have question about my front-end. I already switched out my power-steering and disk brakes with a 72 and it is working ok. But I am bagging my ride to lay frame and I wanted to know if any of you guys fabricated your xmember and lifted it so it would go lower? I have a 65 long bed. Thanks. |
06-25-2009, 05:11 PM | #2 |
Re: Xmember Fab Question
06-25-2009, 11:46 PM | #3 |
60-66 Nut
Check out the suspension forum on here. Porterbuilt makes a real nice dropmember.
06-26-2009, 12:00 AM | #4 |
SSN 706
But that would take all the fun out of cutting up a good crossmember. I have an extra one just sitting out there waiting.
06-26-2009, 12:38 AM | #5 |
Me too ...and a dropmember
06-26-2009, 09:02 AM | #6 |
SSN 706
I'd go work on it today but I don't have a way to cut it. It seems like a grinder would'nt work very good. I might take it down to the local blacksmith and see what he'd charge. What a new drop member cost?
06-26-2009, 10:04 AM | #7 |
a grinder and a thin cut off wheel should work well.....
never-mind I see the issue now....a torch or a plasma would be the best way to cut it
CHEVY ONLY Last edited by joe231; 06-26-2009 at 10:07 AM. |
06-26-2009, 11:04 AM | #8 |
Plasma would be ideal, but it could be done with a 4.5" cut-off wheel and sawzall.
06-26-2009, 11:09 AM | #9 |
the sawzall is your friend I also have a pneumatic 90* die grinder with a cut off wheel attachment, the wheels are 2 or 3 inches in diameter and will get in tighter spots than the 4.5" grinder. there is always more than one way to do it As Frizzle says..."It is only metal" bend it to your will, young Jedi if only we had light sabers, it would "cut" down on fab time
CHEVY ONLY |
06-26-2009, 01:03 PM | #10 |
SSN 706
Any idea what Portbuilt charges for a drop?
06-26-2009, 01:14 PM | #11 |
think the front drop-member is $1000-$1200
CHEVY ONLY |
06-26-2009, 01:15 PM | #12 |
SSN 706
Do you need that to lay frame?
06-26-2009, 01:19 PM | #13 |
Um.. I like the opposite sex better than frame, but it is just me.
Sorry, couldn't resist. I don't THINK, you could modify the factory frame enough to lay the frame on the ground, but I could be wrong. I was wrong before, but it was in a land far, far away.
Don't let my username fool you, I have become brand blind. Cool is cool, period. 1965 C-10 - "Whipping Post" 1958 Biscayne - "Ruby" 1961 IH Scout 80 - "Gaucho" (My wife's new project) 1938 Chevy - unstarted project. |
06-26-2009, 01:25 PM | #14 |
SSN 706
I must be getting old because i seem to care more about laying frame then getting layed. I still need to know if I need a drop to lay frame.ya ya lay frame ya.
06-26-2009, 02:27 PM | #15 |
Member of the longbed union.
you could either get the PB crossmember, or the ***************** Crossmember. I personally have the SD crossmember and I like it better then the PB, because it use's less welded peices together. But they are build the same. Check out the SD one on their webiste. Both are priced $1200. I know the SD one also comes with shocks, mounts, engine mount, trans crossmember, heim joints for steering, rack notch. It's a really good kit.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
06-26-2009, 02:29 PM | #16 |
SSN 706
Sweet. Now all I need is a extra $1200. I'll check out the site.
06-26-2009, 02:46 PM | #17 |
SSN 706
Damn, I could really get in trouble there. Where's my wifes credit card anyways. Thanks for the info.
06-26-2009, 05:32 PM | #18 |
You can lay frame with a chopped xmember too. And/or Z'ed frame. All depends on how tall your tires will be. You just don't get r/p steering. Also, the PB dropmember comes with all the parts mentioned. Except I don't think either comes with shocks.
06-26-2009, 05:46 PM | #19 |
Resistance is Futile
FRENCHBLUE72 had his work sectioning a crossmember on his build thread. I think you can get pretty damn close to laying frame on a stocker if you raise it 1.5''. Dino had a modded stock x-member on the orange GMC 'burb and it was very low. I think you still end up sitting the cross shafts on the ground first....not sure.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by ChiefRocka; 06-26-2009 at 08:14 PM. |
06-26-2009, 05:49 PM | #20 |
bent doesn't necessarily mean it is stronger than welded either......
Porter was the originator, and the latest version of the dropmember has a very slick way to mount the lower arms.....
CHEVY ONLY |
06-26-2009, 05:55 PM | #21 |
Couldnt edit.......its FRENCHBLUE72...missed the 'H' up above.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-26-2009, 06:03 PM | #22 |
found this thread for ya......his newest version is bent and welded...
http://67-72chevytrucks.com/vboard/s...d.php?t=323437
CHEVY ONLY |
06-26-2009, 06:11 PM | #23 |
SSN 706
Nice pics on the french build. I have a 66 crossmember and a 71 crossmember. The 71 stuff will fit one the 66 right. I'm thinking chop,chop.
06-26-2009, 06:14 PM | #24 |
Yessir.......pics please!!!
06-26-2009, 06:27 PM | #25 |
Yes, please inspire me to chop my spare
