Old 06-29-2009, 10:18 PM   #1
lokeondubs
1981 CHEVY C10
Sanden 508 ac compressor???
Do anyone on here have a sanden ac compressor.Im thinking bout getting a chrome one.Where u get the ac lines for to fit it?Im going to have to get special ac brackets because my heads dont have holes in them.Can I use this compressor with my same accumulator and all my other ac stuff.If u have one .post pics,,thanks..
1981 C10
lokeondubs is offline   Reply With Quote
Old 06-30-2009, 12:27 AM   #2
dan76
Re: Sanden 508 ac compressor???
As long as the brackets allow for mounting the unit, it should no issues with the other A/C components. Try the stock hoses prior to getting custom hoses, might work well.
dan76 is offline   Reply With Quote
Old 07-04-2009, 11:53 PM   #3
DubDubU
DubDubU's Avatar
Sorry for the delayed post. I replaced my stock A6 compressor with a Sandon. Mines on a big block. I got a bracket from Alan Grove. Had to experiment with about a dozen belts till i found one that worked due to tall valve covers. Sandons fitting are a different size that stock, so new hoses and the tube on the bottom of the accumulator had to be cut and a smaller fitting welded on the fit the new hose. Let me know and I will take some pics if you are still interested. Also I was told the chrome one runs hotter that the polished one and the chome isn't garenteed to stay on.
'79' shortbed
DubDubU is offline   Reply With Quote
Old 07-05-2009, 12:00 PM   #4
dan76
I'd like to see the pics....
Old 07-05-2009, 12:41 PM   #5
lokeondubs
1981 CHEVY C10
I want to see some pics also.What all do i have to replace??
1981 C10
Old 07-05-2009, 02:10 PM   #6
boatpuller
boatpuller's Avatar
here's a couple of pics of mine.i have ran the lines different since these pics.but,you get the idea.you'll probably have to take it to a shop that does a/c work and have them crimp the ends on your hose's.they'll have the end's.then you can get it charged too.alan grove can hook you up with brackets for your head's and system.their good to deal with.i just called them and told them what i wanted.the polished compressor i have does get hot.i wasn't aware of a chrome one when i bought mine a few year's ago.they are a big improvement over stock monster.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-05-2009, 03:49 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice, BP
Malo83 is offline   Reply With Quote
Old 07-05-2009, 08:07 PM   #8
lokeondubs
1981 CHEVY C10
nice,,which brackets did u use,he have different types.I dont have holes in my heads also
1981 C10
Old 07-05-2009, 08:09 PM   #9
lokeondubs
1981 CHEVY C10
Where is your ac box?Do u have vintage air?Did u use same condenser
1981 C10
Old 07-05-2009, 09:36 PM   #10
DubDubU
DubDubU's Avatar
It's not as clean as BP's but it works just fine.
'79' shortbed
Old 07-06-2009, 04:30 PM   #11
lokeondubs
1981 CHEVY C10
nice,,what all did u have to change?condenser???lines?
1981 C10
Old 07-06-2009, 07:41 PM   #12
DubDubU
DubDubU's Avatar
check my original post. bracket and belt. compressor hoses and weld a fitting on the bottom tube from the accumulator. the rest is all factory.
'79' shortbed
Old 02-03-2011, 10:08 PM   #13
masterjohnson
Wow i really like boatpuller's engine. That is cleaner than our home! Check this out! This is why i love saden chromed A/C compressor. Looks very clean all the time.
masterjohnson is offline   Reply With Quote
Old 02-04-2011, 11:46 PM   #14
primrrd
primrrd's Avatar
i had started a similar thread that got some good responses:
http://67-72chevytrucks.com/vboard/s...d.php?t=413979
no hose modification necessary with this little beauty:
http://www.nostalgicairparts.com/air...ad-back-16.php
description:
Sanden 508 / SD5H14 Compressor back (head). The head has a GM Pad mount for original GM hoses. This back has five bolt holes to mount to the rear of the compressor. Any Sanden five series compressor with five bolt holes on the rear will accept this rear head. The head includes the rear gasket.
and ... its only 29.99- much cheaper than modifying the hoses.
description:
primrrd is offline   Reply With Quote
