Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-01-2009, 12:59 PM   #1
oldno7
oldno7's Avatar
?'s for you guys
OK so what are you guys doing as far as rearend's go. For example To my knowledge they do not have c-clip eliminators for are truck 12 bolts, and some of you seems to have some power going to the ground. Also I am curious about setting the pinion angle so any help their would be nice. I would like to run 10" street lite's with 325/50r15 any one have these or similar setup thank all oldno7
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 07-01-2009, 02:33 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: ?'s for you guys
http://www.summitracing.com/search/B.../?autoview=SKU
Last edited by tnblazerk5; 07-01-2009 at 02:36 PM. Reason: put wrong link frist time lol
tnblazerk5 is offline   Reply With Quote
Old 07-01-2009, 08:16 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
im running a 67-69 rearend housin, with the tubes welded to the hogg's head, moser 33 spline spool, moser 33 spline 5 lug axles, moser c-clip elimnators, and a mark williams billet bearing cap. rims are 15"x10" with 4" backspacing with a 28"x10.5" slicks. chris
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 07-02-2009, 08:21 PM   #4
69trk
69trk's Avatar
I have the same rearend with a full spool and a moser billet yoke.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 07-02-2009, 09:06 PM   #5
mongoose
mongoose's Avatar
i'll be using the stock 12 bolt.. with the 3.08's.. welded up good and proper...
doubt it would last a good launch... but the saggy wouldn't either.
how much power are you planing on putting out?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-03-2009, 12:37 PM   #6
oldno7
oldno7's Avatar
My plans are to run the zz572. The prob is that I have this prob of going in reverse so to speak. I've always build my projects from the rear up. So This is just getting going after a few years of decisions. My plans call for a dana 60 35 spline-posi with a 4.56 gear on bil spe draglites 15-10 and 325/50/15's ET street radials 28" tall. That's why I asked about the pinion angle. I don't think it has the brackets so I will be setting up the rear myself. If anyone has this tire rim combo I'd like to see it
oldno7
Old 07-12-2009, 08:25 PM   #7
Ont67shortbox
DTS makes housings for our trucks with the brackets on.They did the rear for Project Copperhead.
Ont67shortbox is offline   Reply With Quote
Old 07-12-2009, 11:29 PM   #8
scatesracing
Machinist
scatesracing's Avatar
I built a nine inch.......
scatesracing is offline   Reply With Quote
Old 07-13-2009, 12:51 AM   #9
Super73
Super73's Avatar
I had a factory 12 bolt with a Eaton posi in mine last time at the track. There were Zero mods to it so I thought. When it was redone with the 4.56's we found aftermarket axles in it (not sure who makes them). But the shop had a truck 12 bolt there that we used some C-clip E's off and Moser axles. Same Eaton but a set of 4.56's went in it.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-13-2009, 05:38 AM   #10
RatPwrd72
RatPwrd72's Avatar
I'm running a narrowed car twelve bolt from a 69 camaro with welded tubes, Mark Williams spool and 33 spline axles with Richmond Pro gears.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 07-18-2009, 11:37 PM   #11
djracer
djracer's Avatar
9 inch for me!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-21-2009, 01:10 AM   #12
BigDan3131
BigDan3131's Avatar
The truck 12 bolt isn't the same internally as the car version as I was told by a chassis guy I know. If I were going to be racing my ride full time I would go 9 inch. Only because you can change out the third member quickly at race time. I will be going Dana 60 as well since I believe in overkill
BigDan3131 is offline   Reply With Quote
Old 07-21-2009, 03:01 AM   #13
mongoose
mongoose's Avatar
no its not.. truck 12bolts have a smaller pinion shaft dia.
