Old 01-06-2003, 11:27 AM   #1
jmil1974
Ain't we cute?
jmil1974's Avatar
Q-Jet Misbehavin'. Why?
Well, after adjusting my carb to where she seems to run ok ... she's still a little finicky. She tends to want to idle high until I "reset" by goosing the throttle, in gear. There's little or no smoking or pinging so I'm pretty close anyway. Any ideas? I'm also getting sh*t MPG, about 9 or 10 where I used to get 13. Could the Torker manifold be to blame? It's a 350 with a mild cam and I think the carb is a 650, not sure on that one. When I swapped motors, I just cleaned the carb up a bit and readjusted, no kit or anything. Any help would be appreciated.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 01-06-2003, 01:01 PM   #2
racedvl
racedvl's Avatar
How's your timing?
racedvl is offline   Reply With Quote
Old 01-06-2003, 01:13 PM   #3
jmil1974
Ain't we cute?
jmil1974's Avatar
Pretty darn close. While I don't know what cam I have exactly, I good Chevy mechanic helped me set it with a light. I think it ended up at 10 BTDC, but I wouldn't swear to it.I was just so happy to hear it start and idle. hehe
FOR SALE $3900
Old 01-06-2003, 01:41 PM   #4
6869704X4
When you cleaned and adjusted the carb, what did you do? If you just hosed it with cleaner you might have broke loose some crud that has found its way down into carb.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 01-06-2003, 02:14 PM   #5
tom hand
CCRider
tom hand's Avatar
Unless you have a motor that spends most of its time at a drag strip, I would be using the torker manifold for a doorstop. With a mild cam, stock compression, etc they really suck. You would be better off with a stock manifold. As a bandaid you can run a bunch of timing with a single plane manifold, proably more than the starter will tolerate. That might get your gas mileage back up a little
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
