One Piece Drive Shaft what options?
I bought a ECE drop trailing arm crossmember from a member. what is my best option to converting to a one piece drive shaft. my truck that i'm building is a 70 swb with 71 running gear and will be bagged. i'll most likely be using a 350 or 700r4. thanks
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: One Piece Drive Shaft what options?
If your 350 is mounted in the front frame holes on proper small block mount stands and you run a 700 R4, you can get a driveshaft out of an 88-98 regular cab Short bed V8 automatic truck.
I've done this twice myself. Only caveat is that you will need a conversion u joint on the rear since the early model 12 bolt rearend you have uses a larger series of u joint than the later truck did. The conversion u joint is available at any O Reilly or Autozone store.
its all about the +6 inches
Being that you are going with bags, you are better off keeping the 2 piece shaft. With a single shaft anf adjustable suspention, you are very likely to have the shaft hitting the crossmember.
for the two piece, what about the drive shaft attachment on the new ece crossmember?
never seen one.
Does this piece have a larger opening for a one piece shaft? |
any ideas where to get a one piece driveshaft for a shortbed?
i had a shop chop the ends off my two peice and make me a one peice i just specified the lenth i wanted they hacked and slashed one out for me. it was about 200 but its beafy as heck.
hope this helps josh
My build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=348729 |
![]() Join Date: Jun 2006
I am running a 700R4 on my 68 swb. I took a 72 longbed one piece shaft and the correct yoke for the 700R4 and had a driveshaft shop shorten the saft and istall the yolk. The stock rear joint fit the rearend perfect.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
I had a one piece built by a local driveline place new joints and tranny yoke for $225.00 zero vibration it has been there for almost a year..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
