Old 07-24-2009, 03:06 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Engine Bay Paint
What do you members recommend as a good economical engine bay paint? I am going to start stripping the front clip of my 82' in preparation of putting on some " new to me " sheet metal.
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 07-24-2009, 04:07 PM   #2
JohnC
JohnC's Avatar
Re: Engine Bay Paint
I am planning on using just some semi-flat, or satin black Ace Rust Stop paint, or Krylon.
JohnC is offline   Reply With Quote
Old 07-24-2009, 08:51 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
i currently have blue metal flake, and black.. the, entire engine bay is going to be clearcoated this week... soo (50 bucks ) for clear cote and 50 bucks for spray paint...
(well inr eality i did about 150 bucks in spray paint but i did alot ALOT of changing of the mind..)
click on my linky below and you will see (on the last pages) the progress
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-24-2009, 09:29 PM   #4
fixit-p
fixit-p's Avatar
If you can find it locally Barnes distribution makes the best spray bombs ever (mho) it's a high solids paint.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-24-2009, 11:10 PM   #5
texasfunk
texasfunk's Avatar
i just use an engine paint, i clean everything with a red scotch brite and water with a little soap, cleans and sands so the paint will stick, then just paint, has always worked well for me
texasfunk is offline   Reply With Quote
Old 07-24-2009, 11:21 PM   #6
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I've always been happy with underhood paints from Eastwood.
78 Big10 454 is offline   Reply With Quote
Old 07-24-2009, 11:52 PM   #7
COMP
Rustolum
COMP is offline   Reply With Quote
Old 07-25-2009, 12:09 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Make sure what ever brand you use is a satin, NOT flat. Flat will show streaks, runs, and eventaully stains. Satin will look nice for a long time if applied smoothly.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-25-2009, 12:30 AM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
I only use valspar Tractor & Implement Enamel spray paint available at Tractor supply cheap and durable
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-25-2009, 08:17 PM   #10
85sqbdy
85sqbdy's Avatar
rustoleum satin black cut 15% with acetone. lays out real nice.
if it ain't broke, fix it until it is.
85sqbdy is offline   Reply With Quote
Old 07-25-2009, 08:21 PM   #11
COMP
i haven;t thinned it before ,,what about thinning gloss ??
Old 07-25-2009, 08:36 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Zero Rust!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-25-2009, 08:45 PM   #13
COMP
Originally Posted by gchemist View Post
Zero Rust!!
never seen that
Old 07-25-2009, 09:06 PM   #14
85sqbdy
85sqbdy's Avatar
never tried the gloss rustoleum paint. i'll see if i can get pint and experiment.
Old 07-25-2009, 10:07 PM   #15
COMP
let me know ,,, i like gloss cause its easier to clean
Old 07-25-2009, 11:26 PM   #16
gchemist
gchemist's Avatar
never seen that
I found Zero Rust while searching for POR-15. Zero Rust is better than POR-15. Zero Rust is more of a paint than POR-15. I like it! I'm using it on all the frame. I'll soon do the rear and bed underside. I'll post pictures. I'm using a regular air paint gun.
Old 07-26-2009, 12:09 AM   #17
85sqbdy
85sqbdy's Avatar
a friend of mine has his front end disassembled. he painted his inner fenders base coat/clearcoat black, and i don't think it can get any better.I like rustoleum paint because of the durabilty. But for gloss, his looks friggin sweet.
Old 07-31-2009, 11:42 AM   #18
ECU PIRATE
ECU PIRATE's Avatar
Thanks Men. I might have to give the Zero Rust a try. I was just going to use some good old Rustoleum since the have it at the local Advance. Never failed me before
The Fleet........
Old 07-31-2009, 06:40 PM   #19
Ryan87
POR 15 makes great engine bay paints! We just used some on a 71 challenger we are restoring @ my work. The hemi orange we used was a spot on match.
Ryan87 is offline   Reply With Quote
