Old 08-04-2009, 09:05 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
ol curt floor saga
Getting near the end on the floor. Made a quasi patch panel for the passenger side kick panel out of an old piece of sheet metal from a farm implement.
Now I started to remove a couple of seat bolts that I thought were coming out nicely when they snapped off. I tried several methods....welding a bolt to it and trying to get it out. Couldn't get a good ground and the weld would always break. Used an easy out and it was budging some....broke off the easy out! Next I just cut the section of the floor surrounding it out. After looking at it I wonder if I welded a piece of bar steel to the floor patch, welded patch to floor, marked seat hole, drill and then tap if that would work. Any thoughts?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-04-2009, 10:10 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: ol curt floor saga
I would think that method should work just fine. Also noticed a square nut in your pic. You could probably weld that on your patch and have it 'pre-threaded'. Say 'Hi' to everyone at the hardware store again.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-04-2009, 11:26 PM   #3
daverod
SSN 706
daverod's Avatar
You need to start a build thread and put your ? on there. Then I would'nt miss half the stuff you do. Looks like your plugging along.
daverod is offline   Reply With Quote
Old 08-05-2009, 07:05 AM   #4
ol Curt
Junior Member
ol Curt's Avatar
Unfortunately, they know way to well! The square nut is left over from one of the mounts for the cab. Do you think that would be an item a hardware store would stock?
I have one started called ol curt progress, but it doesn't have very many followers, so I just post them seperate!
Old 08-05-2009, 07:29 AM   #5
70 Suburban
Rods
I get my square nuts from mack botl and steel
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-05-2009, 02:27 PM   #6
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
well, you're committed now..lol
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 08-05-2009, 04:39 PM   #7
ol Curt
Junior Member
ol Curt's Avatar
Or should be!
