ac
ive got an ac compressor for my truck without a clutch, after i repalce the clutch, how do i draw a vaccuum to recahrge the system?
its all about the +6 inches
Re: ac
you need A/C tools for this.
I'll move this so someone will see it. It was posted on the electrical board. |
Re: ac
you need a vac pump that can draw the system down to 29 inches to remove all traces of moisture.
Re: ac
Where do ii fet one if those
Re: ac
a automotive repair shop, its a pricey elec vac pump, our a/c machine at the dealer was 10k....but it also recovers the system and recharges it. its not one of those tools a most guys have at there house it would seem...??...
Moderator
![]() Join Date: May 2007
Re: ac
You can buy a 2-stage R-12 and R-134 vacuum pump from Harbor Freight for $150.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Re: ac
as far as i know this has no oil in it, will the oil type matter what referigrant i use?
Moderator
Re: ac
Yes, R-134 and R-12 use different types of oil. If you have never done this before, I would recommend you go to an A/C shop or do more research before you attempt to do this. I am guessing that you will be using R-134 since you can no longer buy R-12.
Re: ac
I dont know about california but in texas you can buy R12 with a refrigerant handling license (a multible choice test) R12 is a superior refrigerant. nothing works like it in a R12 system. You will need a/c gauges a vacuum pump. mineral oil for R12 synthetic pag oil for 134A. if using 134A in a r12 system put 10% less refrigerant.
Re: ac
Before you put that new pump on,you should flush the system to remove any debris and old dirty oil.
Could save you some money! I can still buy R-12 here.I'm certified also. Mike. Last edited by 100%Chevy; 08-09-2009 at 10:03 PM. |
