Old 08-14-2009, 09:38 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Posi or Locker?
I have an 84 K10 with dual 10bolts, 3:42 gears. I want to have a posi or locker in the rear, but which is better? I dont offroad much, and it HAS TO BE 3:42 for a 8.4/5/6 10 bolt truck rear end, preferably cheap not expensive. So basically, what should IO get? Posi or Locker? Anyone have any good links to parts or info? All help appreciated.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-14-2009, 09:51 AM   #2
LONGHAIR
Re: Posi or Locker?
For street driving and clutch-type Posi-traction unit is much more "user friendly". Lockers are harsh, do a lot of clunking and banging, and are somewhat unpredictable to a novice. They take some practice to master. It is generally not a good idea to "just let anybody" drive it. They can cause a front end push when the pavement is dry or a wildly loose rear end in the rain....of course the more power you have, the more exaggerated this becomes.
A plain ol' Eaton posi.....not Gov-lock, is a great way to go.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-14-2009, 10:26 AM   #3
Manbearpig
Manbearpig's Avatar
Re: Posi or Locker?
Detroit Tru-Trac
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 08-14-2009, 11:01 AM   #4
Sniper X
Re: Posi or Locker?
You only need a locker if you are going mudder or rock crawling so no locker...posi all the way. How bout a lock right? I hear they work well on the street and are cheap.
Sniper X is offline   Reply With Quote
Old 08-14-2009, 02:12 PM   #5
nlped
nlped's Avatar
Re: Posi or Locker?
Ooh, I had a lock rite in my old Toyota and it was terrifying in the rain. My Jeep has a Detroit Locker front and rear, but it is an off road toy primarily. I put a Eaton Posi 10 bolt under my '87 GMC 2wd and it does wonders for pulling my boat out, even on a wet/steep launch. It is also smooth on the road. Just my .02.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-14-2009, 02:24 PM   #6
Sniper X
Re: Posi or Locker?
I never drove a lock right on a wet road. But they work phenominal in the mud, and on dry pavement but truely you can't beat a posi for street use.
Old 08-14-2009, 07:53 PM   #7
Manbearpig
Manbearpig's Avatar
Re: Posi or Locker?
word
1972 GMC C10
Old 08-14-2009, 08:31 PM   #8
nlped
nlped's Avatar
Re: Posi or Locker?
A Lock Rite isn't a "posi", it is a "LOCKER", hence the name LOCK.
Carter
Old 08-15-2009, 11:11 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Posi or Locker?
Ive a detroit locker in a 9inch. Its so loud when i turn that people stop me to tell me something has got to be wrong
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 08-15-2009, 06:04 PM   #10
Dave Kay
Dave Kay's Avatar
Re: Posi or Locker?
A truck w/locker used mostly on pavement will wear out rear tires twice a fast as front tires... gone thru three sets of rears in less than 100k. So I've never been stuck in the soft stuff but forget about rotating tires.
Dave Kay is offline   Reply With Quote
Old 08-16-2009, 03:59 AM   #11
Manbearpig
Manbearpig's Avatar
Re: Posi or Locker?
" This is a mechanically-operated unit which locks when power is applied, giving full power to both tires, and unlocks when you let off the gas."
It can be considered both.
1972 GMC C10
Old 08-16-2009, 08:37 AM   #12
LONGHAIR
Re: Posi or Locker?
Ah....no, it can't. A "locker" has to have the ability to "un-lock" or it is just a spool. A locker does positively lock together with square edged teeth, no slipping.
I clutch-type "limited slip" (Posi-traction is GM's word) works just like it sounds. It allows one axle to "slip" so that it can go at a different speed. This keeps one tire from squeeling during turns. The "limited" part comes from the friction of the clutches. The amount of pressure applied to them and the amount of "grip" they have affects the amount of slipping. A really tight Posi unit in a really light car may still squeel the inside tire in a low speed sharp turn.
The word "LOCK" in some cases is just a marketing thing that sounds tough. As an example: Eaton's "Gov-lock" .....it is NOT a locking differential. It is a clutch-type posi-traction unit that has a "variable pressure" mechanism that can apply more pressure to the clutches. It never gets any more than a traditional posi, but it it will loosen-up to the point of acting more like an "open" differential.
Old 08-16-2009, 02:22 PM   #13
thirdstreettito
Resident of Here
Re: Posi or Locker?
Thanks guys, so where can I (for a good price) get a 3:42 posi for a GM truck 10 bolt rear?
~Bradley~
Miss having a truck
Old 08-16-2009, 02:59 PM   #14
3r!c84
Badass
3r!c84's Avatar
Re: Posi or Locker?
what no one likes the one wheel wonder?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-17-2009, 08:08 PM   #15
thirdstreettito
Resident of Here
Re: Posi or Locker?
Anyone?
3r!c84 - It is fun in coldesacks at full throttle, it makes a PERFECT circle.
~Bradley~
Miss having a truck
Old 08-17-2009, 08:18 PM   #16
3r!c84
Badass
3r!c84's Avatar
Re: Posi or Locker?
lol havnt tryed that.
i got pulled over for flooring it at a stop sign.didnt even spin and the cop shows me the marks and im like thats not me,if it was it would be one line.lol he laugh and said true and let me go.
-00 Saturn 5spd
1/4:13:90
Old 08-18-2009, 12:16 AM   #17
Manbearpig
Manbearpig's Avatar
Re: Posi or Locker?
www.ringpinion.com
If you have a 10 bolt it is probably a 8.5" ring gear.
They don't make "3:42 posi's" either BTW
They make posi carrier's and you can get a 3.42:1 R&P set seperate if you feel the need to swap them.
1972 GMC C10
Old 08-20-2009, 08:35 PM   #18
3r!c84
Badass
3r!c84's Avatar
Re: Posi or Locker?
this is what it should look like
-00 Saturn 5spd
1/4:13:90
Old 11-28-2009, 10:13 PM   #19
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: Posi or Locker?
sorry to jack your thread but I was wondering the same thing. my truck will be seeing its fair share of mudd and offroading but still be street driven, so I was wondering if a locker is a good choice or?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
