Old 08-16-2009, 08:11 PM   #1
dan42
dan42's Avatar
differential overflow hose question -
Does anyone know if this hose on the diff is suppose to pull off, or is there a clamp? I can't tell and I don't want to screw it up by pulling too hard.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-16-2009, 08:14 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: differential overflow hose question -
There is a clamp. The hose is actually a vent and not an overflow.
--Josh
Old 08-16-2009, 09:45 PM   #3
jaymc32
Just had mine off, mub dobers had it plugged real good. It pulled off even with the clamp in place as the original rubber was hard as a rock, the hose fell to pieces when I tried to clean it out. I replaced mine with about 2.5 feet of 5/16" fuel tubing.
jaymc32 is offline   Reply With Quote
Old 08-16-2009, 10:12 PM   #4
dan42
dan42's Avatar
My bad, overflow. Is the clamp the kind you pinch together with pliers or a screw type?
Philippians 4: 6-7
Old 08-16-2009, 10:19 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If stock, I believe it's the pinch type... well at least the two rear ends I worked with were.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-17-2009, 04:19 PM   #6
71 super
71 super's Avatar
The clamp is a pinch type and if you are wanting to restore the original color was a creamy yellow. In order to be absolutely correct there is also a vent installed in the end of the hose (really a one way check valve to prevent mud duabbers and other things from getting into the housing.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
