Justified!
drop spindle question quic
Will drop spindles for 73-87 fit my 72 front end
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny
Resistance is Futile
Re: drop spindle question quic
Yes, but you may need to change balljoints and I'm not sure about the tie-rod ends. The calipers may be different for the early years, also....I'm not familar with the 71-72 stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Yes, they'll swap.
The upper BJ's are the same for sure... I can't remember if there's a difference on the lowers but if there is, you simply use the 73-up lower on the 72 a-arm. You should be able to also use the 72 drag-link w/the 72 inner & 73-up out tie-rod combo.
Justified!
They had some 3" drop spindles at the car show, but by the time I got back around they were gone...100.00 seemed like a good deal....
A c-note for 3" spindles is (was) a good deal.
| Bookmarks |
