Old 08-26-2009, 10:02 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Cab Corners?
Does one of the vendors sell a cab corner that is bigger side to side or in particular, wraps farther around the back? I need to put one on my passenger side to finish up, but the rust extended further around the back than the other side. I think I bought he other one from Classic Parts, but another like it wouldn't come close to covering the space.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-27-2009, 01:15 AM   #2
Captainfab
60-66 Nut
Re: Cab Corners?
I can't say for sure, but I'm thinking they're all the same. You might have to extend the corner with some 18ga to take care of the rust. Unless you can find a cab to cut that piece out of. I had to do that on a '67 I'm working on to fix the mess the PO made trying to scab in a cab corner.
Old 08-27-2009, 09:42 PM   #3
100%Chevy
Re: Cab Corners?
I bought 3 for my 64 GMC---None of them fit worth a damn!
3 different suppliers!
None were big enough!
And none were shaped right!
Mike.
100%Chevy is offline   Reply With Quote
Old 08-27-2009, 10:06 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
Re: Cab Corners?
Ohhhh, all you sweet talkers, you have me feeling really positive about this!
Old 11-23-2009, 11:40 PM   #5
brawley
Easy Does It
brawley's Avatar
Re: Cab Corners?
I was trying to replace my cab corners tonite, but they don't seem to fit right also there is a big gap between where the rockers and cab corners come together underneath???? is there something im not doing right???? anybody got any pics or is there a thread showing how this is done? thanks
brawley is offline   Reply With Quote
Old 11-24-2009, 12:57 AM   #6
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Cab Corners?
Check out this build (post 23) he tried different ones and finaly found some that fit. LINKY
Alan's Classic is offline   Reply With Quote
Old 11-24-2009, 10:50 AM   #7
brawley
Easy Does It
brawley's Avatar
Re: Cab Corners?
Hey Alan, thanks so much!!! I really appreciate guys like you for your help,and you have one hellofa build thread 82 pages. thanks
Old 11-24-2009, 12:16 PM   #8
joe231
joe231's Avatar
Re: Cab Corners?
I just got cab corners from Tx Firefighter, he got them from Classicparts.com and one was a good one and one was the bad one, they looked just like this pic from 65Custom's thread
I called classic and they happily sent me another to match the good one. I'm not 100% sure, but I think the smaller one may be for the 67-72's actually..........
here are the pics of mine
Name:  counterpart corner.jpg
Name:  cab corners 002.jpg
Name:  cab corners 008.jpg
the counterparts corner is the crappy one....
CHEVY ONLY
Old 11-24-2009, 12:29 PM   #9
mbgmike
Re: Cab Corners?
mbgmike is offline   Reply With Quote
Old 11-24-2009, 12:59 PM   #10
joe231
joe231's Avatar
Re: Cab Corners?
Originally Posted by mbgmike View Post
what???
CHEVY ONLY
Old 11-24-2009, 01:13 PM   #11
mbgmike
Re: Cab Corners?
Originally Posted by joe231 View Post
what???
I was just being onery Joe
Good old counterparts
Old 11-24-2009, 01:16 PM   #12
joe231
joe231's Avatar
Re: Cab Corners?
Oh I see...
guess counterparts has a reputation, huh?
CHEVY ONLY
Old 11-24-2009, 03:46 PM   #13
Alan's Classic
Re: Cab Corners?
Old 11-24-2009, 08:38 PM   #14
65Custom
Re: Cab Corners?
I had to learn the hard way cost me twice as much as it should but in the end I got the parts that fit petty dang good
I took a queue from Alan he told me he had to use two to get hem to work and did some research and bought the second set which were better than the first set I got
I thought that I was going to have to use two to make one as he did
I think that some one bought a boat load of bad parts and they decided to sell them
The smaller ones are for 60 to 66 the are just bad stampings
the ones from classic parts are thicker material, have a bigger door jam lip and the weld flange at the back wall is formed correctly but it does not fit exaclty it needs a little work to get it where it should be
also the shape at the bottom that meets the rocker is correct and more defined than the other cheaper parts
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 11-24-2009, 09:15 PM   #15
joe231
joe231's Avatar
Re: Cab Corners?
both of the ones pictured above came from Classic Parts......
CHEVY ONLY
Old 11-24-2009, 09:27 PM   #16
frmula505
frmula505's Avatar
Re: Cab Corners?
The ones I bought didn't fit perfect either (Classic Truck Parts). One side was fine, cause I didn't use the complete corner. The othe side needed some work to fit. Nothing to hard since I was already welding in that area. The rear edge didn't qiute line up. You can see I had a small bump on the bottom edge (fixed since this pic).
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
