pictures of 60-66 on a 73-87 4x4 frame ?
I picked up a 77 k20 yesterday and I am planning on putting my 1965 c20 on that frame. Does any one have picture or a build thread of a 60-66 on a 73-87 4x4 frame ?
Thanks. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: pictures of 60-66 on a 73-87 4x4 frame ?
It won't be much different than putting it on a 2wd frame.....you'll have to build all new body mounts on the frame. You'll end up with a 3" or so body lift when done....BTDT. The other option is to channel the body down over the frame. Either way it's a bit of work.
The only two threads I can think of that will show somw of this is one by JoeyAP and Oklahomaduner
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-28-2009 at 12:12 AM. |
i'll get some good pics of it tomorrow, but it's not a terrible swap. the frame is already a z so you don't need to do much as far as mounts, but you will need to move them from the 73+ body location which leaves the frame horn extending forward of the front clip. you'll need to mod the front of the frame back and line up with the rad support. here's a pic that does hardly any good, but my wife thought it was hilarious that i was having to fix my starter in a parking lot in the rain (it wouldn't even jump with a quarter between the starter posts, but then again, i was with my wife....rather do a 20 minute starter replace than a 2 hour fight lol)
'64 4x4 Stepside 350/sm420, going L92 in the near future '05 GTO that gets more attention than my truck '69 Jeepster Commando that needs more attention than my truck '71 wagoneer that gets less mpg than the gto |
Thanks guys. I would love to see more pics tomorrow. Here a few pictures I took from a truck I saw locally. It works but seems a little to crazy.
#5 | |
...wow...i'll get pics for you tomorrow...please don't mimic what you've just posted:edit:...whats with the duct strap?
'64 4x4 Stepside 350/sm420, going L92 in the near future '05 GTO that gets more attention than my truck '69 Jeepster Commando that needs more attention than my truck '71 wagoneer that gets less mpg than the gto Last edited by sixfour4x4; 08-28-2009 at 01:14 AM. |
60-66 Nut
Man! some of the sh!t people do......that right there is a hack job. It definitely should be done better than that. I don't really have any pics of the one I did 16 or 17 years ago. sixfour4x4 should be able to shed some light on how it should be done.
Not sure if it will help but on my other truck (4WD) a common low buck trick it to use hockey pucks for a body lift.
They would fill the gap in photo #2. |
#8 | |
I've changed my plans on this truck so many times.. I am on my third motor and transmission & bed and It hasn't even seen pavement yet ! I want to get this truck painted before it gets too cold here in utah. I miss the CA weather. |
#9 | |
sorry for forgetting about this thread. what you ought to do is use the back 2 sets for your cab as is, then fabricate new bodymount/spring hangers for the front and move it forward several inches to bring the shackle off of the frame. you can just weld in a steel plate to offset the bodymount from the spring hanger so everything still lines up fine, but alleviates the shackle from riding on t he frame. you'll be left with the frame horn sitting well in front of your bumper, chop it off
#11 | |
What is the best way to mount the cab with out moving the suspension ? I do not want to move the shackles because I have a stupid state safety inpection and they frown on custom welding for suspension parts or major frame welding. Thanks again. |
Hey does anyone have pictures of this swap ?
I am interested in photos of front radiator support. What do you use for the body lift ? I have a three inch body lift but what if i don't need it to be three inch. I am not sure how it would work if i cut them. Thanks for your help. |
#13 |
you WILL need to make body spacers for the core support and the fron cab mounts but the rear you can use a single 1" standard body puck.
my old, now rebuilt by my freinds 66.
#14 |
Thanks for your help. Truck looks awesome. I wish I could afford tire that big.. Tires are so expensive !
Any idea's on where to get 1" body mounts ? Thanks again. |
| Bookmarks |
