Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-07-2009, 07:52 PM   #1
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Question ? on building a 4L80E
My plan is to build a 4L80E so i can run a low gear ratio for track, but have ability to drive to the coast, and show's.
  1. Is there a year that i need to look for? It's going behind 406 sbc
  2. Who's controller to use or do I need one with full manual valve body?
  3. Who's performance rebuild kit Should I go with? (most complete)
  4. Who would make a low slip converter?
  5. How much do I need to shorten drive line?
  6. What drive line yolk do I need? I currently run a 3/4 ton BBC, TH400 drive line
  7. What needs to be done for trans cross member?
  8. How much is reasonable price to pick one up?
  9. @ this time should I convert to one piece drive line?
Thanks for everyone's in put and advise in advance.
Mike
Last edited by 68 C-10 KID; 09-08-2009 at 12:41 AM. Reason: Better wording and alterd ?'s
68 C-10 KID is offline   Reply With Quote
Old 09-07-2009, 10:31 PM   #2
Super73
Super73's Avatar
Re: ? on building a 4L80E
    1998 and earlier have a sbc/bbc patern on the bell housing. 1999+ are gen 3/4 bolt pattern. I'm running a 1993 behind my LS1. All but 1 bolt hole lines up. If you are using an early one with gen3/4 pcm's you may need to change the internal wiring harness and connector like I did.
  2. Is there a trans brake valve body or is it all mods in the stock one?
    There are a couple companies making a trans brake. your best bet is to search performancetrucks.net for info on them
  3. Is a performance rebuild kit enough?
    Again Performancetrucks.net would b a good site for this.
    You could have a silly loose unefficiant converter like I do in it and still have near 100% efficiancy. It's all done with the lock up and PWM percentage. A good aftermarket controller should allow you to do the same I do through a factory PCM.
  5. Who's controller to use?
  6. Is the length the same as th400?
    No it's longer. I could measure mine if you need it.
    Drilling 4 new holes in the fram then welding a piece of plate where the tailshaft mounts and redrilling 1 hole.
    Mine was $600+ shipping. I know where there is a 4wd built one for sale. But, mine is stock minus the verter.
Mike
See red
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-11-2009, 01:10 AM   #3
68 C-10 KID
Mean Green
1. Is there a year that i need to look for? It's going behind 406 sbc90-96 supply and return close together
2. Who's controller to use or do I need one with full manual valve body?No controllers needed for manual valve body
3. Who's performance rebuild kit Should I go with? I'm going W/ transtar Hp kit w/ 34 element sprag and FWD billet hub. (most complete)
6. What drive line yolk do I need? I currently run a 3/4 ton BBC, TH400 drive lineTH 400 will work
I'm looking for 60-67 3/4 ton with 3 speed should be around 3 1/2" dia
This is some of the info I picked up so far. Dry weight, the 4l80E is only 40lbs more than TH400. Some company's offer a tail shaft now that has mech. speed o. The Th400 speed o slides right over shaft.
