09-21-2009, 03:53 PM | #1 |
Young Gun
Shifter linkage help
Okay guys a little background. I bought my 71 chevy with a 83 police intercepter 350 and centerdump manifolds with a turbo 350. I recently switched to headers that a buddy had laying around brand new but im not sure of the brand. My problem is my shifter linkage hits the middle of my collector tube and im not sure how to fix it. Help would be greaty appreciated. Thanks Brandon
09-21-2009, 03:57 PM | #2 |
Ex-Minitrucker
Re: Shifter linkage help
any pics how much clearance are we talking I've seen them dinged with a hammer before to clear stuff, not attractive or the best fix by far but it works and its cheap.
09-21-2009, 04:09 PM | #3 |
Were they for your model truck? I have used a set off of a 69 camaro and they fit up just about like you described. I wound up using a lokar cable but their direct rod should work too.
09-21-2009, 04:11 PM | #4 |
Moderator
x 2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-22-2009, 01:25 PM | #5 |
Young Gun
No pics right now but they hit smack dab in the middle of the collector. I can get it into nutral but thats as far as i can go. Do you guys have a part number and price?
09-22-2009, 03:05 PM | #6 |
Speedway has IDIDIT cables for $110: http://www.speedwaymotors.com/Column...-Kits,406.html
shift rod for $45: http://www.speedwaymotors.com/E-Z-Sh...-Kit,1926.html Summit Lokar cables for $120: http://www.summitracing.com/parts/LOK-ACA-1804/ shift rod for $53: http://www.summitracing.com/parts/LOK-ACA-1800/ |
09-22-2009, 03:29 PM | #7 |
Young Gun
What one would you guys recomend, The rod or the cable?
09-22-2009, 03:49 PM | #8 |
The only reason I can think of going with the cable is if revving/towing will cause the drivetrain to flex enough to change gears for you.
09-23-2009, 01:24 PM | #9 |
Young Gun
well i dont think ill be flexing the truck to much with reving im not going to be over 350 hp or anything so i think the rod should work for me. Thanks alot guys this really helps. Can i get a pick of anyones set up?
10-01-2009, 01:12 PM | #10 |
Young Gun
Okay guys i solved my linkage problem and i gotta take some pics to show you how but it only cost me about $3 total and thats just for the can of black spray paint to stop it from rusting. I modified the lower bracket that comesoff of the side of the transmission where the linkage rod connects to.
10-23-2009, 11:52 AM | #11 |
Did you ever take pics?
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
