Old 09-24-2009, 09:55 PM   #1
dentmaster
6.0 liter HELP
I recently bought a 6.0 for my 72 4X4 ...I want to stay with my factory 4sp manual tranny . Has anbody done this conversion? Can anybody give me imput, on what I am about to get into...any help would be appreciated!
dentmaster is offline   Reply With Quote
Old 09-24-2009, 10:07 PM   #2
72truckman
72truckman's Avatar
Re: 6.0 liter HELP
its a pretty straight forward swap if you keep the original tranny... other than all electronics and fuel system that accompany that motor. correct me if im wrong, but if you order the pilot bearing from ADVANCE ADAPTERS you can bolt up any stock chevy V8 transmission just fine with only one bolt that doesnt line up.
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 09-25-2009, 05:57 AM   #3
vtblazer
vtblazer's Avatar
Re: 6.0 liter HELP
Subscribed.
Always been interested in doing a 6.0 swap.
vtblazer is offline   Reply With Quote
Old 09-25-2009, 07:41 AM   #4
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Re: 6.0 liter HELP
4.8,5.3,or 6.0 swaps are basically all the same.
i am running an sm465 with a newer style alum. bellhousing,hydro clutch setup.bushing in crank is just plain old sbc $5 brass bushing.i bought flywheel and clutch setup from advance adapters.simple and straightforward.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 09-25-2009, 11:37 AM   #5
JimmyFloyd
Re: 6.0 liter HELP
subscribing as well. Been considering this one for a little bit now.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
