Old 01-15-2003, 05:57 PM   #1
Zilverado
Zilverado's Avatar
Question Squeeky Column - Suggestions?
So this is just a little annoying and would love to get rid of it. I have a little squeek in the steering column. It is near the top (steering wheel) and squeeks when I turn. A realize this could be a whole host of things, but I thought I'd just throw it out there to see if anyone else has experienced something similar.
BTW - its a tilt column.
Thanks for your thoughts.
Zilverado is offline   Reply With Quote
Old 01-15-2003, 10:20 PM   #2
pkbinplano
pkbinplano
pkbinplano's Avatar
Pull your steering wheel off, lube everything and then put a custom wheel back on ! Tell your wife your steering wheel went out and you had to get another one.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 01-16-2003, 01:54 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Sounds like the horn ring maybe be rubbing. Easy fix. For instructions on tearing down and replacing back look here http://home.t-online.de/home/O_Scholz/steering.html
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-16-2003, 02:49 AM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
Mine squeaks too, but hopefully I can fix that when I tighten up the tilt.
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 01-17-2003, 12:31 AM   #5
apstguy
LED King
apstguy's Avatar
Mine sweaks bad too. Unfortunately, the screws kept coming out (scary isn't it? Try to turn too fast and.. oops! there goes the steering wheel) so I put some threadlocker in it. I'm just going to live with it for now. {BTW you should hear our 99 Tahoe... it is VERY loud and "farts". We have tried getting the dealership to fix it... several times... but that was a fiasco and a half.}
I had to install the adaptor kit upside down for the wheel to be properly alligned. (when I got the truck the steering wheel was 30 degrees right while the truck was going straight) This is what I think is causing my problem. Check the screws holding the adaptor on & tighten them down. Think about putting threadlocker on them too. It could also be the trim under the adaptor. Make sure it isn't bent or dented.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
