camal hump headsvs 194 closed chamber heads
what is the two hump heads ? most people think there 202 heads
but a engen biulder tould me they where 194 closed chamber. higher compression.
70 chevy 3/4 ton 4x4 402ci crewcab 3/4ton 94 gmc 1 ton dually crewcab 454ci 99 suburban 5.7 2001 500cc ski-doo mxz 95 500cc ski doo fan 650 bombardiar 4 wheeler |
I finally got an avatar
From what I've found, the double hump heads could be 2.02/1.60s or 1.94/1.50s with either 64 or 62 cc chambers.
http://www.jimsperformance.com/headchart.html
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S |
72 shorty is right they came both ways
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
![]() Join Date: Oct 2002
heads
461,462 291 are early close chamber 64cc valve sizes depend on application.have no accessary bolt holes .These are camel humps by nick name or 300 horse heads.also in this catagory are 040 but have no humps and very rare.186 have accessary bolt holes and humps 041 have accessary bolt holes and no humps there are several more castings that are service replacement parts plus the bowties I have collect at least one set of each over the years and run these on my trucks.They do not come with harden seats and must be installed to run on todays cheap gas.You need high octane fuel to run a high compression close chamber head .For everyday usage you are better off with open chamber 76cc heads and factory harden seats with mild compression for pump gas.
I have a set of 040 heads and I was just wondering what they are worth?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
Value
Depends on who wants them and purpose.Generally if you want to sell something everyone wants to steal it. If its not for sale they want it bad.Most of my stuff is not for sale as I collected to build trucks not sale parts.I met a guy who had a 68 z28 with a factory 302 at a car show a couple of years ago.He had 041s on his motor and I noted to him they where incorrect for his # matching restore.He knew this and was searching for 291 uncut castings dated Jan through Mar 68.When I told him I had a set he offered $800 right off the bat if the dates where right.I wasn't trying to sell just picking over details with friend on show cars.This was a set I took off a hundred dollar impala with a 327.I have over $1000 in parts and machine work on the 186s on my 406.Good not severely cut stock heads usually show up in the local trader every once in awhile from $150 to $300 Worked heads will sell for $500 and up.I have a set of 040s that I took off a 68 327 300 horse 1.94 1.5 valves The only other set I have ever seen belonged to a local machinest. The only reason I found out they where 300 heads is because I knew the history of the car.It was untouch # matching and build sheet and engine vin said 300 horse power.I was expecting humps.I checked casting numbers and decided to compare with 041s .They were the same except bolt holes .Even the marking on the end of the head is the same.
461
I have 3 sets 461s but only one set has and x I also have 4sets 041s and all have x 461x I have came off early vette and have higher volume runner from the factory I have a friend who runs these on a 67 class car he drags
