Frame parts and brackets
Have a feeling these won't be easy to find, but are frame parts and/or brackets available from vendors or GM? Or will it be a trip(s) to the salvage yard? Also, crossmembers and some brackets are riveted in place. Can frame shops reproduce these rivets, or is it a nut and bolt only replacement option? Thanks in advance.
On your parts, it is either the junk yard or post your needs on the board. I have not seen any new parts for sale in the catalogs or sites.
I am not aware of rivets that will work in the frame although if you had access to a cold header and the right tooling they could be formed easily. Jim |
I have 1/2 and 3/4 ton frame parts for 48-72, also can get you new rivets. e-mail the parts you need.
Rest in Peace Ed. Thanks for all the good times. |
rivets
Back when I was in the military
Progress = 0%
What parts are you needing? I may have some and live in KC.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
![]() Join Date: Jul 2001
I have some frame parts in Texas if I can be any help just let me know.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
I have used lug studs in reamed-to-size holes. They look like a rivet from the outside, are pressed into place, and held on with fine thread nuts. Grade 8 would work, too, if they were an interference fit.
Just as if I knew what I was doin' |
