Old 10-13-2009, 11:48 PM   #1
Devil'S Ride
Smile Fuel Tanks/cells
Ok, so my rig is nothing but a wheeler. I am tired of the stock saddle bag tanks and constantly worrying about mashing one around a tree. I have been considering a burb tank, but don't want fuel hanging that low off the rear of my truck.
Figure my alternatives are an off-the-shelf cell or aluminum tank. Or, to have one custom made. Thinking of placing at the front of the bed, under the tool box, between the frame rails. My problem is that I worry about fuel starvation at angles and ascents/descents.
What have you guys used? Baffled tanks? What kind of pumps? what do you find works best for off road?
Thanks guys!!
-Zak
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 10-14-2009, 01:00 PM   #2
onlyifihadachevy
Re: Fuel Tanks/cells
Someone answer this, I think a sump helps the two little blue things, the foam inside. Got a pic of your rig.
forgot to say the blue thing are below the bottom of the cell for aa sump
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 10-14-2009, 10:05 PM   #3
Devil'S Ride
I have a few more, I'll post up in the "in-action" thread in a few.
I have been thinking about fuel cells. You are saying that they are foam filled? Or baffled? Either way I need something like that. I saw yours in your thread earlier. I am pretty much leaning that direction. What are you using for a fuel pump?
The Devil
Old 10-14-2009, 10:14 PM   #4
onlyifihadachevy
nothing yet, but you need a sump to the blue thing in a box below the bottom of it. The foam should help from going side to side keeping it more stable, The foam is in bricks. some come with it some you have to buy.
There are bladder packs too.
My 72 thread
Old 10-17-2009, 07:44 PM   #5
msgross
msgross's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=362371
he can make you whatever you need for a very fair price..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-17-2009, 09:09 PM   #6
Devil'S Ride
sweet, thanks for the link, I found it while searching too.....i might have to take some measurements and see what he can do!
The Devil
Old 10-17-2009, 09:58 PM   #7
msgross
msgross's Avatar
summit has some poly fuel cells as well.. might be better for the type of wheeling that you do.
The Garage:
Old 10-17-2009, 10:17 PM   #8
onlyifihadachevy
I was thinking of having a alumuim one built, and now that will mst likey happen. My dad knows someone who does welding like that, and now it is just find what i want.
My 72 thread
Old 10-17-2009, 10:43 PM   #9
msgross
msgross's Avatar
They have a group buy going on for rear tanks right now.. I designed the tank but he will let you make changes as needed.
The Garage:
Old 10-20-2009, 12:00 PM   #10
fun in dirt
fun in dirt's Avatar
I used an aluminum fuel cell from Summit $250 http://www.summitracing.com/parts/SU...S/?image=large
It has the foam in it already,baffle about 1/4 of the way from end of tank for sender, and sump by outlet fittings, 20 gallon capacity.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 11-08-2009, 08:54 PM   #11
lowlifeyankee
this is a tank I made for my street truck but would fit in any truck
lowlifeyankee is offline   Reply With Quote
Old 11-08-2009, 09:21 PM   #12
onlyifihadachevy
Nice cell, We are going to make a custom one, We sold the red one because it didn't fit. We plan on building a sump too.
My 72 thread
