the pollock
box dimensions
hey all!
before i go out and start cutting hte hell out of some wood here does anyone have dimensions they used to fit a single 10in sub behind the seat? i got a generic box but im dissatisfied with it... and it has wayyy to much danged airspace in it.. well have fun! thanks for input
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
>130dB Moderator
Re: box dimensions
Sorry for the late reply, I'll get you the dimensions I used from my old box a little later.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Re: box dimensions
I would love this information as well. I'm looking to get enough air space to house 2 MTX TT6512-04 Sealed Enclosure Net Volume = .75ft3
the pollock
Re: box dimensions
thanks ace!
i appreciate it... what dubs you used also etc.. i jsut traded my wife my MTX 4000 due to the fact they sound better in a suv then a single cab. so im going down to ONE sub but it'll be a jlw 10 incher shallow so i an put "less box" de to me being tall and needing my seat all the way back.. plus i still have an amp to mount (off the floor) im thinking i'll put it in the glove box for fun!.. hahaha i miss my behind seat storage... grrrr..
>130dB Moderator
Re: box dimensions
JL only makes a 12 and 13.5 shallow sub, but one should be enough.
Sorry I haven't gotten you those dimensions. my grandpa had to be run to the hospital yesterday and I've been surfing the net using a laptop. I'll get the measurements once I get home.
the pollock
Re: box dimensions
no rush brother
and yes you are correct on the shallow mount dimensions.. the jl 10 im using is not "shallow mount" but the magnet size and depth is better then te mtx 4000's i have.. thus allowing me to tuck it better it all depends on how good of a box i can make myself vs spending 70 bucks on one to fit thanks!
Re: box dimensions
This is the ten in my 92 regular cab...
![]() ![]() ![]() ![]() If this is what you want when the rain stops I can measure it up for you...
"If at first you don't succeed use more duct tape" Red Green.... Danger --if you meet it promptly and without flinching -- you will reduce the danger by half. Never run away from anything. Never! -Winston Churchill A few of my holsters............. |
Re: box dimensions
O thought I would mention I too bought a retail box but I could not push the seat all the way back so I built this.......
the pollock
Re: box dimensions
that is EXACTLY what im looking for thanks!
Re: box dimensions
I will try to get the numbers in the am...
Re: box dimensions
Ok here we go...
Maybe some one can make a diagram out of this for you ???? I used 3/4 MDF with Formica on both sides.. It was what was laying around at work back when I still had a job. In fact we used the CNC router and the program is saved. If I had access I could have whipped you up one in about 5 minutes.... Measurements in inches.. All out side dimensions..... Length 29 wide High 15, This is up the back as the slant on the front will be longer.. Depth at top 3 Depth at bottom is 7 .. Now as for the size of the hole I have no idea as of now and really don't want to pull the sub.. Note that the sub is mounted from the outside, also that it is a sealed box packed with poly fill.... Hope this helps....
Re: box dimensions
One last thing I bought one of these for a grill... Worked out real well for the price...
#13 | |
Re: box dimensions
#14 |
Re: box dimensions
Yes IF you remove the jack and tire tools,,,,,
#15 |
the pollock
Re: box dimensions
the length would nto be the issue for behind the seat on our cabs..
it's the depth at the base.. from the rear cross tube of the bottom half of the bench seat, with it fully slid to the rear you have 7.5 inches... most "generic" boxes are 8-10 inches deep... so at 15inches "up" the back of the seat he has the measurement at three in the allowable space for the top of the box there is a hair under 5 in.. so with speaker mounted grill mounte and wires ran you have mroe then enough room behind the seat to "hear" the sub better and a much less likleyhood of a screwdriver or somethign slipping between the seats and f-ing up his box.. hey dude thank you for the measurements i did a quick cardbpard cutout to visualize it and it's tits perfect!..
#16 |
Re: box dimensions
Happy to help... Post up some pic's when you get it done....
#17 |
Re: box dimensions
is that a shallow mount sub that you have in there?
what is the sound like? get decent bass out of it? im going to build one as well but im trying to decide if i want to build a double or if a single 10 will be enough |
#18 | |
Re: box dimensions
Nope.. Better then I hoped for. Tons of bass JL makes a good sub.. There is way more bass then I need in this thing. If you want to shake the ground go for two...
| Bookmarks |
