Old 10-21-2009, 09:13 PM   #1
jackyl9999
jackyl9999's Avatar
Fuel pump to carb fuel line options
I'm looking for a suggestion on how to plumb my truck from the fuel pump to the carb. I have single line holley. The easy route would be rubber, but the reason I first started working on this truck was because of a fire caused by a cheap specter fuel filter and a rubber line. So does anyone have suggestions? Pictures would be helpful.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 10-21-2009, 09:19 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel pump to carb fuel line options
i ran mine up from fuel pump along bottom of valve cover then up to carb (edelbrock). I dont have pictures but if you REALLY want some i'll go snap some in the dark with a light. lol
John
1999 Toyota Tacoma 4x4
Old 10-21-2009, 09:40 PM   #3
jackyl9999
jackyl9999's Avatar
What material did you use?
1990 K1500 Daily
Old 10-21-2009, 09:42 PM   #4
mclairmo
I used an off the shelf brake line from Kragen to go from the pump to the intake (cut off one end and bent a 90 degree into it) and then connected a metal Spectre fuel filter to it that with short rubber hoses that then connect to a Spectre Chromed Single Feed Fuel line (part no. 2998) that goes to my Holley 4160. Only have about 5 or 6 inches of rubber being used. Pep Boys and Autozone carry the Spectre stuff.
mclairmo is offline   Reply With Quote
Old 10-21-2009, 10:55 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
stel brake line... 3/8 inch
Very easy to do with a bender (10 bucks) and some time to do it right.
Get an extra section of line if you need to learn.
You could always hit up a junk yard for a pre bent piece off another small block.
Old 10-21-2009, 11:01 PM   #6
big_al_71
big_al_71's Avatar
I am not sure if this is what you are looking for take a look at the pict below...
you can see my fuel line from the pump to the carb I used steel braided with anm fittings..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-22-2009, 07:01 AM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
No pics right now (its raining out) but I went the same route Big Al went. Steel braided with #6 an fittings and a double pumper fuel rail on my Holley 670 Street Avenger. BTW Big Al, I'm liking the inline fuel regulator gauge, nice touch in completing your fuel system setup
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 10-22-2009, 07:41 AM   #8
big_al_71
big_al_71's Avatar
thanks Harry...I need to bring my truck by your house....
Old 10-22-2009, 07:58 AM   #9
mrh33916
Project '67 454
mrh33916's Avatar
For a fuel filter use a all metal oem style replacement "barrel" filter.
mrh33916 is offline   Reply With Quote
Old 10-22-2009, 09:23 AM   #10
cdowns
cdowns's Avatar
i'll always go with the steel brake line route or on more fancy engines braided hoses and an fittigs
I HATE seeing the lazy mans cheap rubber hoses on an otherwise nice build // a fire waiting to happen
Old 10-27-2009, 06:26 PM   #11
jackyl9999
jackyl9999's Avatar
I'm Trying to use a 1 piece line from the pump to the carb. Is there any place that I can put a barrel style fuel filter besides between the pump and carb? I was thinking below the tank?
1990 K1500 Daily
Old 10-27-2009, 08:57 PM   #12
myoldchevytruck
That'll be great Albert, just give me a call one day.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 10-27-2009, 09:11 PM   #13
tim21391
tim21391's Avatar
i used brake line like mentioned. i heard the less rubber line u got is best..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 10-27-2009, 09:16 PM   #14
wp silverado
braided here
1967 c-10-built smallblock, backed by m-21, lowered
2005 silverado-tint, exhaust, lift, 35's
1964 c-10 shortbed project
wp silverado is offline   Reply With Quote
Old 10-27-2009, 10:41 PM   #15
chevy_mike
Never Ending Projects
chevy_mike's Avatar
This is what I used on my '69 Camaro. 3/8" aluminum tubing, Edelbrock hard line with filter and AN fittings where everything connected. Very clean.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-28-2009, 01:25 AM   #16
jaros44sr
jaros44sr's Avatar
I bought the alum. tubing and fittings from Speedway(AN ferrule and nut) easy to bend with your hands. Fittings are 36˚, but you can use your 45˚ brake flaring tool, since -6 and -8 are considered multi-angled. Keep your bend as tight as possible down at your fuel pump, since your radiator hose is close by
Adapter in the fuel pump is a inverted flare to a -6 or -8, can't remember
You can put your fuel filter anywhere you want, I used my old coil mount! Still need to finish up the fittings around the filter, and run the new fuel line to the rear
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-28-2009, 01:27 AM   #17
Longhorn Man
you CAN put it anywhere you want, but it's a good idea to put it after the pump to help reduce the chance of vapor lock.
Old 10-28-2009, 10:40 AM   #18
mtdave2
newly minted old timer
mtdave2's Avatar
geez. i never gave a 2nd thought to using.. rubber, silly me, FUEL line.. lol. maybe its just me.
rubber was used forever on cars. i see no problem with is as long as you look every now and then. granted, the metal looks awsome, and i may end up doing it!
have you converted you WHOLE truck to metal? or is it just the one line from the pump to the carb?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 10-28-2009, 01:14 PM   #19
chevy_mike
chevy_mike's Avatar
Actually from the factory, the only rubber was used in the flex are of the in cab tank to frame hard line and from the frame hard line to the fuel pump. All the rest is hard line, even the one from the pump to the carb. I have had a number of old Chevy cars/trucks with the original setup and they all have been that way unless a PO swapped carbs to a non factory stock one and cut the line up by the carb to use a rubber line.
Old 10-28-2009, 05:04 PM   #20
Senator350
Senator350's Avatar
a clockable fuel pump is nice when doing steel braided.
mine wasn't pointed in the right direction and made the length run out.
looks like big al's is a high rise intake, so my fuel line from summit would have been way short on that there.
building your own steel braided might be fun. lord knows bending tubing can be fun when ya get it right
RN U OVR
Senator350 is offline   Reply With Quote
Old 10-28-2009, 08:59 PM   #21
mclairmo
This is the Summit braided and hard line kit I used on my 67 Camaro for my Holley 3310 dual feed. Great quality stuff, no leaks in over 15 years. I believe Summit makes the same thing for single feed carbs and even other carbs like the Edelbrock and Q-Jet.
Old 03-27-2017, 02:49 PM   #22
jondancer
How do you know what size fittings are on the pump and carb?
jondancer is offline   Reply With Quote
Old 03-27-2017, 11:20 PM   #23
HO455
Post Whore
HO455's Avatar
Mechanical or electric pump?
RIP Bob Parks.
Old 03-28-2017, 11:11 AM   #24
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Would be better to ask this in a different post than dragging up an old one. It would probably get more attention.
As far as the size goes... you would need to check with the manufacturer of your pump.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
