Old 10-30-2009, 12:09 PM   #1
DC_Jimmy
any pics of front top to windshield frame bolts?
My Jimmy only has two bolts attaching top to the windshield frame, the two in the middle. On the corners I see two threaded holes in windshield frame and one hole in the top. Is there a bracket to attach the corners? Would love to see pics of what it should look like and advice on what order to tighten down all the top bolts on a new reattachment.
thanks
DC_Jimmy is offline   Reply With Quote
Old 10-30-2009, 12:21 PM   #2
Thealien
Thealien's Avatar
Re: any pics of front top to windshield frame bolts?
bolts go through the visor bracket. My best advice is try to get everything started first. bolting the top on was not fun!
Old 10-30-2009, 01:11 PM   #3
jaros44sr
jaros44sr's Avatar
Gotta agree with the alien! I ran a tap in the holes to clean them out and used anti-sieze
Those old phillips are a pita, so I used a stud with a SS acorn nut, helps with alignment. Then you can use the 2 windshield bolts to suck it in
Be real careful not to cross thread
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-30-2009, 02:35 PM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Tighten them snug, plus 1/4 turn.
I wouldn't go crazy as the nuts in the top are molded in and are unaccessable without cutting if something goes wrong.
Here are what my bolts look like.
Hope that helps.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-30-2009, 02:41 PM   #5
BobbyK
BobbyK's Avatar
The order I tighten is like this.
1st..don't tighten ANY of the bolts down. Get them started by hand to make sure nothing gets cross threaded.
#1-Top goes on and I start all the bed rail bolts.
#2-Then the sun visor to top bolts.
#3- the center 2 windshield to top bracket bolts.
Once ALL the bolts are in and threaded at least a few turns by hand then I'll wrench them all down.
I start with the sun visor bolts then the center windshield bracket bolts and lastly the bed rail bolts.
Old 10-30-2009, 02:56 PM   #6
DC_Jimmy
very, very helpful guys. thanks for all the pics and advice. now I need some visor brackets
Old 10-30-2009, 06:40 PM   #7
swyfor5
swyfor5's Avatar
Excellant info and pic's guy's!
swyfor5 is offline   Reply With Quote
Old 10-31-2009, 01:32 AM   #8
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Exactly how I do it!
Jason
Cap'n Hook is offline   Reply With Quote
Old 10-31-2009, 07:19 AM   #9
vtblazer
vtblazer's Avatar
Great info Bobby.
vtblazer is offline   Reply With Quote
Old 10-08-2011, 11:30 PM   #10
BobbyK
BobbyK's Avatar
Thought I'd add the detailed pic's of the other two bolts.
Center windshield bracket.
Old 10-09-2011, 01:43 AM   #11
71jimmy
71jimmy's Avatar
That's awesome info BobbyK. If no one has said it yet, I will, this should go into the Blazer/Jimmy FAQs.
Only thing I would add is:
Are there any differences bt. the single and double wall tops? I know they mount differently, so are some of the bolts different ie: bed rail bolts. If there is, maybe someone that has those can add to this post so that everything is covered at once.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-09-2011, 08:34 AM   #12
Joe Blaze
Hey jar- what is the purpose of the turnbuckle?
Joe Blaze is offline   Reply With Quote
Old 10-12-2011, 11:19 PM   #13
BobbyK
BobbyK's Avatar
I'll bet it's to align things when putting the top on.
Depending on your body mounts, the windshield + frame can move either forward or back when the top is off.
Old 10-13-2011, 11:57 AM   #14
jaros44sr
jaros44sr's Avatar
I have 1/2 top.....and it doesnt line up quite right at the B post, about a 1/2" off. POput another windshield frame on it. So, I wasnt sure if he put it backtogether right, OR, my floor patch was a 1/2" to long
Easiest way to have a controlled pull was a turnbuckle, but it seems the w/s is correct.....now I have to cut my patch
SAFETY FIRST
AS usual, off topic
Jim
Old 01-10-2015, 05:45 PM   #15
Senorx
Senorx's Avatar
Old thread, good info. Is the double wall top to bed bolts the same as the single wall?
Senorx is offline   Reply With Quote
Old 01-11-2015, 03:17 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
great info....sub'd
Old 01-11-2015, 06:43 PM   #17
Senorx
Senorx's Avatar
These are OEM double wall top to bed rails. It uses 10 bolts and the size is 5/16.
Old 01-11-2015, 06:47 PM   #18
Senorx
Senorx's Avatar
Another pic of the double wall bed bolt.
