Old 11-26-2009, 11:50 PM   #1
Lo78
crossmember
i was looking at my crossmember in my 78 and im getting ready to put a 700r in the truck along with a 5.7 out of a 89 1500. the crossmember in the 89 just goes straight across to the other frame rail and the 78 crossmember has a low side and a high side. will the 78 crossmember work ? thanks steve
Lo78 is offline   Reply With Quote
Old 11-27-2009, 12:06 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: crossmember
If im wrong i will be corrected..but i believe that all you have to do is move the location depending on the length of the trans... the motor will sit in the existing mounts fine
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-27-2009, 12:20 AM   #3
Lo78
Re: crossmember
the transmission crossmember just looks so much differant than the one in the 89
Old 11-27-2009, 01:08 AM   #4
HOGDADDY
HOGDADDY's Avatar
Re: crossmember
On my 86 when I put a 700r4 in just slid original crossmember back and drilled a 2 new holes and used 2 original holes I believe.
HOGDADDY is offline   Reply With Quote
Old 11-27-2009, 08:12 AM   #5
78-5.3
78-5.3's Avatar
Re: crossmember
i did the same with my 4L60E
78-5.3 is offline   Reply With Quote
Old 11-27-2009, 08:31 AM   #6
S10Fan
Old Heap Driver
Re: crossmember
I used a X-Member from a 70 C-10 for my 700R-454 conversion. BUT, my truck had a 250-6 and a 3 speed.
I could be wrong, but I think the high low sides on yours are for exhaust clearance.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-27-2009, 12:46 PM   #7
joe231
joe231's Avatar
Re: crossmember
either will work, but I would use the one from the '89, I don't like the over/under cross-member.
EDIT:
I just realized the 89 is the different body style. I believe the frame is wider on those....just stick with the crossmember in the '78 unless you feel like modifying the '89
CHEVY ONLY
