Old 12-18-2009, 04:26 AM   #1
1950 GMC
1950 GMC's Avatar
How about some pics of your S10 conversion @ ride height
For those of you who have completed your finished ride height on your S-10 conversion can you please post some pics of your trucks at ride height? If you can also include any chassis mods, rim & tire sizes, and the height the body sits from the frame it would be greatly appreciated.
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 12-18-2009, 08:27 AM   #2
junkman1jmc
junkman1jmc's Avatar
Re: How about some pics of your S10 conversion @ ride height
here is my 48 gmc it is bagged on a 87 s10 frame so the ride height changes depending on the road hahaha
junkman1jmc is offline   Reply With Quote
Old 12-18-2009, 01:47 PM   #3
bjcaldwe
bjcaldwe's Avatar
That is what I hope mine turns out like. What is your suspension setup?
bjcaldwe is offline   Reply With Quote
Old 12-18-2009, 02:25 PM   #4
junkman1jmc
s10 bags and cups and drop spindles in front and 2 link in rear with bags on the bars. rides great
Old 12-20-2009, 01:01 AM   #5
50adrod
50adrod's Avatar
got any pics of the rear suspension?
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-21-2009, 08:18 AM   #6
junkman1jmc
i'm fixing to take to bed off to finsh it up. i take some pictures when i get it off aod post them for you
Old 12-21-2009, 10:28 AM   #7
1952ssr
1952ssr's Avatar
Mine is almost complete except for 18"'s on front and 20"'s out back. But this is how mine sits now with 16" extreme wheels. The ride height should be almost the same after checking the tire circumfrance. The body sits off the frame a 4X4 block +/- 1/2 inch measuring from floor pan to frame. Front has 2 inch spindles and 1 inch dropped coils, back has second spring removed and 2 inch blocks.
1952ssr is offline   Reply With Quote
Old 12-21-2009, 11:42 AM   #8
BlueJeep
BlueJeep's Avatar
1952ssr, what did you use for wheel spacers on yours?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-21-2009, 03:59 PM   #9
1952ssr
1952ssr's Avatar
I've got 2 inch spacers front and back.
Old 12-21-2009, 05:25 PM   #10
BlueJeep
BlueJeep's Avatar
How wide are the extreme wheels? I had to do 1" spacers on my 4wd s10 rear to get the 15x7 (3.75"bs) wheels to clear the bedsides with no tubbing, and I'm looking at what I should do on the front. Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-21-2009, 05:45 PM   #11
1952ssr
1952ssr's Avatar
They are 16 X 8 with zero offset.
Old 12-21-2009, 08:55 PM   #12
49ZR2
49ZR2's Avatar
Mines 4" off the ZR2 frame - no wheel spacers up front - 1 1/4" spacers in the rear to make the stock 31" tires fit
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=372267
49 4x4 build
51 Willys frame off beer getter.
49ZR2 is offline   Reply With Quote
Old 12-22-2009, 03:41 AM   #13
1950 GMC
1950 GMC's Avatar
1952ssr, Did I read that correctly 4" +/- 1/2" off the frame? Thanks for sharing.
Thanks,
Garrett
Old 12-22-2009, 10:18 AM   #14
1952ssr
1952ssr's Avatar
I'll go down to the shop tonight and make sure, and take some pictures.
Old 12-23-2009, 10:47 AM   #15
1952ssr
1952ssr's Avatar
I didn't get to the shop last night, was shopping for last minute gifts. Within the next few days off I'll get some pictures and measurements. I'll get back with everyone next week, I don't have the net at home.
MERRY CHRISTMAS
Old 12-24-2009, 03:02 AM   #16
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Heres mine. Nothing fancy done to it. It's stock ride hight for the s10. I think the back of the front fender is about 6" off the ground.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-24-2009, 03:11 AM   #17
1950 GMC
1950 GMC's Avatar
Thanks for sharing everyone. Nickp51chevy how far off the frame does your body sit?
Thanks,
Garrett
Old 12-24-2009, 03:18 AM   #18
1950 GMC
1950 GMC's Avatar
Nickp51chevy, I just read your build thread 3 1/2" thanks.
Thanks,
Garrett
Old 12-28-2009, 10:26 AM   #19
1952ssr
1952ssr's Avatar
Well got in 10 hours of work on the '51 Saturday. Here are some pictures to get a better idea where my cab sits. About 5-5 1/2 inches off between frame and floor pan in the battery mounting hole. Notice in the second, hard to see it but there is a 3/4 piece of square tubing between the top body mount cup and original cab channel. Those brackets were made using the left over frame cut from the back and a s10 body mount bracket.
Old 12-28-2009, 10:30 AM   #20
1952ssr
1952ssr's Avatar
Others: second is from bottom of back of cab to frame about 3 1/2
Old 12-30-2009, 04:13 PM   #21
Dan Bowles
AD Addict
Not a great pic and wheels have changed but:
Stock S10 suspension with 3" blocks in the rear. 2" spacers all the way around, S10 4x4 rear end. Body sits about 5" off the frame (4" blocks and 1" stock S10 body mount). Rear cab mounts are stock '54 shackle mounts. 327/NV3500 5 speed.
About 8-9" to the running board bottom.
Dan Bowles is offline   Reply With Quote
Old 12-30-2009, 11:08 PM   #22
FiftyTwo
FiftyTwo's Avatar
My '52 is mounted 5" off the frame, S10 Xtreme (ZQ8) stock factory lowered front and rear suspension, '79 Camaro rear end, 15x8 Corvette rally wheels, 245/60/15 tires with 1.5" spacers in front, 350 crate motor with 700R4 trans.
FiftyTwo is offline   Reply With Quote
Old 12-30-2009, 11:34 PM   #23
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
trucks look good guys
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-31-2009, 12:01 AM   #24
LEEVON
Moderator
LEEVON's Avatar
Way to keep this thread going! I've got to have one of these trucks!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-31-2009, 02:06 AM   #25
nickp51chevy
FiftyTwo, Nice! Your truck is awesome looking. I was going to do the same thing with my gas filler neck also, but I didn't want to chance screwing up my bed side so I didn't. Instead I put a wood box in the back of the bed. Check it out in post number 16.
LEEVON, you don't want one of these truck. J/K I think that we should try to save them all.
Had;
