Old 12-18-2009, 08:39 PM   #1
tonyscustomrides
ignition question, confused really
so on my 81 c10, the idle has always been rough since i bought it. it shakes and smells like its burning really rich. so today i bought the idle adjustment tool for the quadra-jet carb, and i started to mess with it. no luck, so next thing, i checked the timing, the timing mark was behind the marker about an inch and half. Then i noticed the distributor was was really angled towards the front of the truck (the plug in on the left side faced very far forward) so i compared it to my 77 chevy and its almost parallel with the firewall. So then i checked the position of each spark plug wire on the distributor cap, and they are all back (clockwise) one position. so number one cylinder is actually on number 8. so i moved them all to the correct position, rotated the distributor to the correct location and the engine doesnt even crank over, so i moved them back to how it was and it runs, but has the rough idle and when you rotate the distributor to get it in the correct spot, it totaley dies.is any of this normal for the wires to be plugged in like that and that much rotation on the distributor? does this mean the engine is pretty worn out and someone messed with the timing like that so it would run? sorry for the long question.
77 chevy k10 Bonanza-Restored when i was 17
76 chevy c10 short box-scrapped
81 chevy c10 silverado short box-project
64 impala 2 dr hard top-project waiting to get started
tonyscustomrides is offline   Reply With Quote
Old 12-18-2009, 09:13 PM   #2
rigon4
rigon4's Avatar
Re: ignition question, confused really
Sounds like some one pulled the dizzy out and put it back in a tooth or two off. Pull all the plugs out of motor put turn the motor to top dead center on #1 cylinder (front driver side cylinder) check were rotor is at if not at #1 pull dizzy and move to #1. you will have to play with oil pump drive to get it to fall back in were you want it but the problem will be fixed
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 12-18-2009, 10:31 PM   #3
GMC Guy
GMC Guy's Avatar
x2
you'll want to re-adjust your carb after you get the timing dialed in
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
