![]() Join Date: Dec 2008
Lowering my 71 c-10 with leaf spring rear end
I want to lower my 71 c-10, but it has a leaf spring rear and the only thing Ive found so far is to buy new springs from CPP. but tht would set me back $400.Id like to drop the rear 4". Has anybody else done this and if so what did you use? Also someone told me that its rare to have leaf springs on a c-10 2wd, Is this true? Thanks for any help
Moderator
![]() Join Date: May 2007
Re: Lowering my 71 c-10 with leaf spring rear end
You can have your springs de-arched by a shop, or try removing a few leafs. You can also use shackles to lower it by 2".
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-24-2009 at 02:24 AM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
ECE (Early Classic Enterpises) also sells a drop leaf spring and a drop shackle.
You can do a flip kit
check out his http://67-72chevytrucks.com/vboard/s...d.php?t=319981
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
Brakes and Suspension related FAQ's will get you headed in the right direction. See link below:
http://67-72chevytrucks.com/vboard/s...d.php?t=157669 ![]()
![]() 1972 Chevy Cheyenne LWB 350 engine TH400. |
![]() Join Date: Mar 2007
Axle flip would probably be cheapest. Leafs aren't as common as coils in 2wd most people say all GMC's are leaf and Chevys are coil I have found that not to be true. I have a 68 GMC with leafs and its lowered with a axle flip and C-notch.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
I did a flip kit when I had leafs and it gave me about a 5 inch drop. While I had it apart I added 1.5" drop shackles and a c-notch too. Its bagged now.
do a flip kit ..best bang for the buck..i put one on my 2000 gmc and my 1972 chevy lwb (my chevy has leaf springs)
Thanks for all the ideas, Ill probably do the flip but Ill check out all your suggestions Thanks
![]() Join Date: Feb 2009
I bought the lowered leafs for my 71 cheyenne. They are not re-arched, instead they use a reversed eye on the rear. I also took the helper spring out.The wheel wells are exactly 30" from ground to center of wheelwell with 275/60/15. They fit perfect. Hope this helps
