Old 01-01-2010, 11:07 PM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Need help....what frame am I sitting on?
I thinking about 4" lift and some 35's...will that combo work without rubbing?
I have been told the truck is not a factory 67-72 4x4 frame but a 70's Blazer conversion.....I dont know the difference by sight. What do I look for or what can I take a picture of the figure out what I have so I can order the lift.
Any help would be appreciated.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-01-2010, 11:34 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Need help....what frame am I sitting on?
It has a full time 203 transfer case. If it's a blazer frame you should see a weld in the frame between the cab and rear wheels. A 69-72 blazer had a 104 inch wheelbase. A 73-91 blazer had a 106.5 inch wheelbase. They could of used blazer drive train in a pickup frame...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-01-2010, 11:38 PM   #3
b454rat
That shock mount is no way from a 73-87 truck, never seen one like that.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-02-2010, 07:30 AM   #4
If it`s a`73-up the core support mounts will either be moved back or it`ll be mounted through the frame...improvised.The front frame horn ends are different.You know what the 67/72s look like.Check how the bumper and core support are mounted.I believe the tips of the frame would need cut off to keep the bumper back where it belongs.The`73-ups are longer in the front.Also look or moved or unused body mounts on the frame.The truck has the rear cab and front bed mounts close and the Blazer only has a single pair.
Old 01-02-2010, 05:55 PM   #5
72freak
72freak's Avatar
a few pictures of the frame, front end and spring hangars......
What do you all think?
Old 01-02-2010, 09:37 PM   #6
I think it`s a post-72.1)Are the frame ends modified up front? 2)Are those bolt in the front spring hangers? 3)the crossmember for the ront sway bar,is that original looking?67-72s didn`t have one there.I have a sway bar on my`72 and a c-channel is bolted in to accept the center mounts.
Old 01-02-2010, 09:54 PM   #7
msgross
msgross's Avatar
those front springs mounts are SCARY looking... check out diy4x for some new ones... also missing a bolt in the rear spring hanger...
newer than 72 like special-K said..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-02-2010, 10:22 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
Not sure what frame you have for sure maybe 73-80? I'm pretty sure that none of the spring mounts were bolted on like yours. Good Luck!
ps, what's up with Barrett Jackson? on your sig?
mcbassin is offline   Reply With Quote
Old 01-02-2010, 11:41 PM   #9
72 CustomCamper
huh ???
Looks to me like somebody took a 67-72 c10 frame, used 73-79 4x4 parts and made a 67-72 k10...
Chuck
Old 01-03-2010, 07:26 AM   #10
72freak
72freak's Avatar
I dont want this to turn into a Barrett jackson thread so PM has been sent.
Old 01-03-2010, 07:29 AM   #11
72freak
72freak's Avatar
Chuck
This was my thought......the VIN on the cab is a 2 wheel drive. The frame has not been cut and it looks like a 67-72 frame, especially up front. I think they added later suspension, cross member, sway bar and running gear to a C-10 frame. All the components are bolted in. i will look at the cross member later today to see whats up with it.
What years do he spring hangars look like?
Old 01-03-2010, 09:53 AM   #12
I`m going with 67/72 2wd with later 4wd fitted,more that I look.It`s not a K/5 frame,the frame horns look right, and why would the stuff be bolted if it was already a 4wd frame?
So,what lift kit?The thing to do is measure springs eye to eye.I`ll guess you need a`73-up kit.The post-72 front springs are shorter and the rear don`t matter.There were two possibilities and they always want to know which anyway.I forget the difference in lengths.You get yours and we`ll see what a`72 is.It`s about 2 1/2-3",I believe.
Old 01-03-2010, 09:57 AM   #13
msgross
msgross's Avatar
it looks good on the outside!
The Garage:
Old 01-03-2010, 12:27 PM   #14
72freak
72freak's Avatar
THANKS....Ive had it for over 10 years....its tight, runs and drives great, draws a lot of attention and seems to have been a pretty nice build. Tilt, tach, AC. Its for sale also!
