Old 01-13-2010, 10:25 PM   #1
1moretoy
how low can i go?
im in the middle of building a 70 short fleet with a turbo charged ls1. i like the looks of a bagged truck but was told i will never get all the power to the ground as if i did a static drop. is this true? can someone post pics of the lowest static drop there is with 20's all around thanks
1moretoy is offline   Reply With Quote
Old 01-14-2010, 12:01 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: how low can i go?
Bags can be properly set up to handle as well as coils. Unless you're making a large amount of power and trying to drag race, which I assume you're not- based on the 20s, you will have no problems. You can do a static 5/7 or 6/8 drop and be plenty low enough and not have to worry about the extras that come with bagging. All depends on what you wanna do...
Check out user Raguemo- he has a white '67 dropped 5/7 on 20s...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-14-2010, 12:34 AM   #3
72hotrodder
THE TOY STORE
72hotrodder's Avatar
bags are just springs that are adjustable. nothing more nothing less. aplying power to the ground will all be based on your suspention (2 link 3 link 4 link) and shock setup.
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know.
72hotrodder is offline   Reply With Quote
Old 01-16-2010, 12:28 PM   #4
1moretoy
any pics?
Old 01-17-2010, 01:58 PM   #5
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Check in with Tony and the guys at www.ridetech.com they had a full on drag car running an innovative air springs suspension that had no trouble getting the power to the ground. You'll have more trouble hooking up due to the empty bed and weight ratio of a truck than anything relating to the air suspension.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 01-19-2010, 08:57 PM   #6
damnyankee36
damnyankee36's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...&postcount=809
damnyankee36 is offline   Reply With Quote
