Old 01-28-2003, 06:20 PM   #1
Snowbound
Snowbound's Avatar
Question Myth or Fact?
We all heard that the rear coils from GM A body cars can be used as rear lowering coils on our trucks. Has anyone actually done this? How much drop did you get? I was thinking the springs from an A body wagon which should have a pretty good load rating.
Anyone...............?
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 01-28-2003, 06:42 PM   #2
crazy longhorn
Fabricate till you "puke"
I have heard that also, but havent tryed it......& really have to wonder about the load rating.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-28-2003, 07:45 PM   #3
jku72
It should work, I did the reverse in order to stiffen the springs on the rear of my 67 catalina. Now, it has a little more sporty feel than before, when it was like a ride on the ocean. If it works one way, it should work the other.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 01-28-2003, 10:46 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
I took the front springs out of a 1/2 ton 68 and put them in my 67 Camaro when I put the big block in it. The ride height was perfect and so was the spring rate. It seems like I did cut them a little bit though!?
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-29-2003, 03:17 AM   #5
casey
casey's Avatar
I think they would work great on a street machine, But as longhorn said I don't think you would want to carry to big of load with car springs,
casey is offline   Reply With Quote
