Old 01-25-2010, 09:22 AM   #1
78-5.3
78-5.3's Avatar
narrowed rearends
just wondering how many guys have narrowed rear ends under there trucks!! what did you use ? how much did you narrow ??? 10 bolt , 12 bolt, 9in, s10, ?? how wide did you go on tires after it was narowed ive seen big tires on these truck without narrowng im just wondering about rearends that are narrowed!! im sure this is posted somewhere too ! but im starting to get the rearend stuff together!!
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 01-25-2010, 09:31 AM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: narrowed rearends
Very good questions 78-5.3,
I've been gandering around here at fat tired trucks and starting to like the idea for my 74 project !!!
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-25-2010, 09:40 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
alot of us are just using wheels with a good amount of back spacing .... I'm haveing a set of sock rallies widened to 12" for a set of fatties ot you can buy something....just keep in mind that if you get to wide your going to need to tub it
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-25-2010, 09:50 AM   #4
Restrorob
Restrorob's Avatar
Tubbing is no problem, How much back spacing can you go before getting into the springs ?
I've heard of moving the springs inboard, Thoughts on that ?
Also, Where can you get wheels widened at ?
Thanks !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 01-25-2010, 09:52 AM   #5
Hottrucks
Hottrucks's Avatar
my truck is a 70 so I have swing arms....just a quick measurement on your truck and you'll know I would look under your truck and decide how much you want to spend..If I was going to go though that I would put in a 4 link
Old 01-25-2010, 03:23 PM   #6
78-5.3
78-5.3's Avatar
im thinking about taking 5 inch of each side 4 bar setup inside the chassis and tubs
Old 01-25-2010, 08:48 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Contact Crawdadfox. Here one that he did-
Originally Posted by crawdadfox View Post
... On my old 87 with a "mild" 5-6 drop i ran a reverse barrel 20x10 Torque Thrust with 3" of backspace and a narrowed rear. ..2" per side for a total of 5" of backspace, and it looked like a 12" rim....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-25-2010, 10:00 PM   #8
CoggedBelt75
CoggedBelt75's Avatar
12 bolt truck rear with Moser big Ford axle bearing housing ends
end to end measures 44"
Convo-Pro 15x14 with 4 1/2" backspace
31x18.50R15L Hoosier Pro-Street Radials with 18" sectional width and 14.5" tread width......tire to inside of lip 2 3/4"
33x16.00-15 Goodyear Eagle slicks with 19.90" sectional width and 16.30" tread width......tire to inside of lip almost 1"
stock frame with c-notch
4-link and coil-overs
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 01-25-2010, 10:25 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
If you aren't going to crazy with the power you can get something from narrower vehicle. I know a guy that put a 8.5 inch 10 bolt from a car under his truck and it worked well and tucked the wheels in a little.
You can also check out a 8.5 inch 10 bolt from an S10, or even a Ford 8.8 from an Explorer as they are both pretty narrow. The 8.8 would be preferable as it's comparable in strength to 12 bolt.. You will need to have the axles redrilled for 5x5 but it's less work that narrowing a rear.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-25-2010, 10:53 PM   #10
Ceeten
Like them big ole lips!
Ceeten is offline   Reply With Quote
Old 01-25-2010, 11:02 PM   #11
3r!c84
Badass
3r!c84's Avatar
got any pics of the set up under the truck?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-26-2010, 05:12 AM   #12
SRD art
S10's came with a 7.5" rear and don't hold up well to a great deal of power in stock form. 10 bolts are pretty strong. An 8.8 from a Mustang would be ideal, that's a tough rear and newer ones come with disc brakes. Trouble is 5 on 4.5 bolt pattern but you can have that redrilled.
Are you just looking for fat meats or a deep offset? Seems fat meats can tuck with a stock frame and the right offset wheel. Maybe widening the tubs just a bit too?
Wheel Vintiques makes steel rallies up to 14" wide and will do custom offsets. I ordered 6 lug Corvette style rallies for my 76 Burby in 15x8. They were cheaper through Summit Racing than direct through Wheel Vintiques. That was several years ago, but I imagine that's still the case.
-Ben,
Check out my website!
http://www.streetroddesigns.com
1977 C2500 'Burby w/454
1979 Olds Cutlass Pro Touring wagon "Pumkinator"
1985 GMC S15 Slammed Daily Driver & Autocrosser
SRD art is offline   Reply With Quote
Old 01-26-2010, 12:53 PM   #13
Restrorob
Restrorob's Avatar
Thanks Ben,
I'm running a small block @ about 350hp. It won't be a racer or DD, Only cruise nights and shows like my 97. Was just looking at bigger meats to bump the wow factor up a half notch without breaking the bank.
Guess I'll have to wait till I get the cab and bed back on and do some measuring if no one chimes in with specs.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 01-26-2010, 01:59 PM   #14
AirMale
AirMale's Avatar
This is perfect. The total width of rear should be 49" with axles. wms to wms
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 01-26-2010, 03:50 PM   #15
78-5.3
78-5.3's Avatar
the mustang pre 94 were 4 stud right ? are we talking a 94 on mustang rearend or an explorer rear end? the stud pattern wouldn't be a problem to leave as the wheel would only be suitable for the rear that wide!!!!
how wide are the stang or explorer rearend anyone know????
Old 01-26-2010, 04:03 PM   #16
AirMale
AirMale's Avatar
I think you may not understand. If you are refering to the "housing ends" these are aftermarket housing ends that are welded to a narrowed stock rear. They are better for a couple of reasons:
1. they eliminate the c-clips that are vulnerable at high hp/torque
2. they incorporate a wide sealed bearing at the axle end which is pressed on the axle itself and held in place with a retainer/collar that keeps the axle in the housing in case of axle failure.
86 SWB 9.0 LITER
Old 01-26-2010, 05:39 PM   #17
74 C-30
Dually Pride
74 C-30's Avatar
14 bolt cab and chassis axles are narrow, if you want 8 lugs
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
