Old 01-26-2010, 12:23 AM   #1
1969stepside
1969stepside's Avatar
rear disc
has anyone converted their rear end to a rear disc set up i need all the info that i can get thanks
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 01-26-2010, 12:30 AM   #2
chevy71c10
chevy71c10's Avatar
Re: rear disc
I'm currently converting mine this week. I purchased the 4 wheel disk kit w/ cross-drilled/slotted rotors from Classic Performance Products. Will updated with pics and info when done, however will be AWHILE before it sees the road.
What specific info you looking for? Vendors, parts, instructions, etc...?
Best of luck.
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 01-26-2010, 12:39 AM   #3
copywritten
CopyWritten
copywritten's Avatar
Re: rear disc
What lug rear end are you running? I bought a conversion kit from kaptinfab here on the board that utilizes 95 impala ss rear disk breaks. I just installed it today! You can do the entire conversion for around $200
copywritten is offline   Reply With Quote
Old 01-26-2010, 11:37 AM   #4
OhOneWS6
OhOneWS6's Avatar
Re: rear disc
Another vote for CaptianFab. I decided to use the F-Body calipers to keep an e-brake. Gotta have it for inspection here in TX. Do a search in the suspension forum. There are several options. Many have done it.
OhOneWS6 is offline   Reply With Quote
Old 01-26-2010, 11:53 AM   #5
copywritten
CopyWritten
Re: rear disc
because we have sooo many hills here in TX that if we didnt have an emergency brake we would be in for it!
Old 01-26-2010, 11:58 AM   #6
Seraph
Seraph's Avatar
Re: rear disc
hahaha!!! no kidding!
1972 chevy c 10 longbed
2000 Ford Powerstroke (daily driver)
Seraph is offline   Reply With Quote
Old 01-28-2010, 04:46 PM   #7
1969stepside
Re: rear disc
i wanna keep the e brake and i need instructions vendors and all tha good stuff
Members i Have met
Earl Slick68
Old 01-28-2010, 06:42 PM   #8
capev86
Re: rear disc
if you have 6 or 8 lug wheels.....use the factory rear disc setup from a 2000+ gm truck. millions of dollars invested in r&d - not a mix of parts, the e-brake setup is better (rugged separate drum instead of in the caliper), and replacement parts are available at the local store. i love aftermarket parts (poly bushings, braided brake hoses, etc), but if there is a factory part that is comparable (or better) i automatically go that route.
capev86 is offline   Reply With Quote
Old 01-28-2010, 07:59 PM   #9
DPowers
DPowers's Avatar
Re: rear disc
CaptainFab
DPowers is offline   Reply With Quote
Old 01-29-2010, 12:22 AM   #10
1969stepside
Re: rear disc
i have a 72 5 lug rear
Members i Have met
Earl Slick68
Old 01-29-2010, 09:12 PM   #11
big_al_71
big_al_71's Avatar
Re: rear disc
Best of luck.
What part number did you buy?
Do you have a link?
thanks
AL
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-29-2010, 09:30 PM   #12
energiesource
Re: rear disc
Do you have a link?
thanks
AL
this might help
http://www.classicperform.com/6092chevtrk.htm#42
i might recommend these brake kits too
http://www.mcgaughys.com/newproducts.html
energiesource is offline   Reply With Quote
Old 01-30-2010, 12:53 AM   #13
chevy71c10
chevy71c10's Avatar
Re: rear disc
Do you have a link?
thanks
AL
Here is the part # from CPP I used: 6772FRBK5 along with option 3 (Crossed Drilled & Gas Slotted Rotors) & option 5 (powder coated calipers).
Link also:
http://www.classicperform.com/Store/.../6366FRBK5.htm
Hope it helps!
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Old 01-30-2010, 12:05 PM   #14
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: rear disc
i bought my kit from CPP as well. overall i would recommend the kit..... but the instructions leave a bit to be desired. i wish they provided more detail. i feel the update is worth the money, no matter which one you choose. good luck!!
P.S. i have a '72 chevy 5-lug rearend....
rodstored-72 is offline   Reply With Quote
Old 01-30-2010, 02:45 PM   #15
grs
Re: rear disc
I put disk brakes on the rear of my 69 C-10. The calipers have emergency brakes. One side emergency did not work. The company is shipping me another caliper. No charge for shipping. The truck stops real good, but the pedal is a little spongy. I think disk braked are a little spongy.
grs is offline   Reply With Quote
