Old 01-31-2010, 07:22 PM   #1
creamsicle68
Edelbrock an t.v. cable
hey, i just got an edelbrock performer carb on my truck and the stock mount for the tv cable and the throttle cable dont seem to line up right and it seems like the tv cable wont be on right. so i went to get one of the mounting brackets from tci and all their thing says that their brackets wont work on the edelbrock performer series? so is there mounts and things that fit the performer series that will let me get the tv cable set up right or am i just at a loss here? ive tried serching for info on seting up the tv cables but it all just seems very confusing and i havent been able to come up with any definite solutions.
Thanks, Dalton
creamsicle68 is offline   Reply With Quote
Old 01-31-2010, 07:35 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Edelbrock an t.v. cable
edelbrock should make one for the application... I have the same situation with my 82 and we were able to get one through pep boys
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-31-2010, 07:45 PM   #3
creamsicle68
alright thanks, do you think advanced would be able to get one also? sorry its probably a dumb question i just have a better relationship with the local advanced guys as compared to the local pep-boys.
Old 01-31-2010, 07:50 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I made my own brackets for my truck and my son's with some plate metal and cut out the holes that I needed for the throttle cable and the TV cable to mount into. I made mine to sit on the diver's side back carb mount bolt and welded a pin to sit into the other flange mounting hole on the carb foot to keep the plate from moving when I stepped on the gas.
The plate is bent UP to allow for the throttle cable and then there is a piece welded to the bottom to allow for the TV cable to mount. This allowed me the ability to make it where the TV cable fit the best and had the right stroke on it.
Try O Reallys, the one in my town has parts for installs, also.
Frank
piecesparts is offline   Reply With Quote
Old 01-31-2010, 08:14 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Order the correction bracket from www.jcwhitney.com. They have the lowest price.
Use this intake bracket.
Correction angle bracket picture.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-31-2010, 08:21 PM   #6
clinebarger
Dont buy just anthing. First thing to do is understand how the Throttle Valve cable,TV plunger,TV plunger spring,carb linkage work together. heres some links, READ all of it.
I strongly advise you buy a "TV made easy" kit from them.
How it works.
1. http://www.tvmadeez.com/article/index.php
2. http://www.tvmadeez.com/article/part2.php
3. http://www.tvmadeez.com/article/part3.php
Intructions for edelbrock/carter AFB http://www.tvmadeez.com/1406_cam/
Kit http://www.bowtieoverdrives.com/cata...php?ITEMID=213
clinebarger is offline   Reply With Quote
Old 01-31-2010, 09:26 PM   #7
MR .T
MR .T's Avatar
It is so easy to set up the tv cable, I dont know why it has this stigma that its a black art or something. If you look at the cable where it fits into the bracket it has an auto adjustment built into the desgn. Just push the D shaped plastic button in with a screwdriver then push the slider all the way in and hook up the cable to the carb. it should not have much movement, then get into the car and floor the pedal. The adjuster will slide back out and its done.
MR .T is offline   Reply With Quote
Old 01-31-2010, 09:29 PM   #8
creamsicle68
thanks alot guys, since i got this truck ive ben trying to read up and understand the t.v. cable as much as possible because of how important it seems to be. i understand somewhat how it workes and all of that i just cant seem to figure it out to wear i comftorbly understand exactly what to do. that kit looks like it might be the ticket. i would try and make my own setup, but i have limited acces to beeing able to fabricate things.
Old 01-31-2010, 09:46 PM   #9
clinebarger
I wish it was so cut & dry. BUT ITS NOT
Old 01-31-2010, 09:52 PM   #10
MR .T
MR .T's Avatar
That is how they did it on the production line. Ive used this method and it works.
Old 01-31-2010, 10:04 PM   #11
clinebarger
Yes i know most people think that this is correct, and for a stock car/truck with a factory 700R4/4L60 it whould be close at best. With a aftermarket carb with aftermarket brakets/cable, the transmission might last a few hundred miles.......Im guessing you did not read the links.
Old 02-02-2010, 05:21 AM   #12
HOGDADDY
HOGDADDY's Avatar
I used these same brackets (for Edelbrock carb) on my 700r4 (in my 86 truck) along with a 87 chevy truck TV cable and it is simple to set-up and mine has been running fine for several years.
I agreee people make this out to be harder than it really is.
HOGDADDY is offline   Reply With Quote
Old 02-02-2010, 12:34 PM   #13
87Bob
How it works.
Great links and a great post.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 02-02-2010, 01:43 PM   #14
joe231
joe231's Avatar
I believe this one should work for you
http://www.jegs.com/i/JEGS/555/157301/10002/-1
CHEVY ONLY
Old 07-27-2010, 03:19 PM   #15
67_ShortFleet
67_ShortFleet's Avatar
Great information to have.
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 07-27-2010, 03:55 PM   #16
jitteryguy
GoatLube Experss
jitteryguy's Avatar
that is the bracket I used on my S10 with a 700R4 and an Edelbrock carb, works good. you can make it work bout any way ya want, but a carb set up for a TH350 or 400 has a different range of motion than a throtle body set up for a 700R4 so if you run that trans with a carb you need the corection bracket. Edelbrock also has a cable mount that bolts to the intake , price'y but very solid and worth the money.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 07-27-2010, 05:56 PM   #17
bluex
bluex's Avatar
How it works.
I agree. I have an Edelbrock 1406 and used their setup on my '78 and have not had to touch it since it was installed 6 or 7 years ago. They also give you a sheet to write down all your pressures and you can call them and they will let you know if it is installed right. Great company to do buisness with...
bluex is offline   Reply With Quote
Old 07-27-2010, 07:58 PM   #18
HOGDADDY
HOGDADDY's Avatar
That is the bracket I use also xcept mine's not chrome.
Gotta have that too!
