Old 02-09-2010, 03:42 PM   #1
mikie 1954
Question Another brake convertion ?
FIRST: My truck is a 1964 GMC 3/4 ton with stock drum brakes. SECOND: I have a 1974 chevy 3/4 ton that I bought about 20 years ago to use on the ranch as a slave . i used it untill the moter gave up the gost, the transfer grumble so I parked it about 5 years ago. NOW MY ? CAN I use the power brake booster from it on my gmc with drum brakes, and if so what is involved . thanks MIKIE
mikie 1954 is offline   Reply With Quote
Old 02-09-2010, 04:29 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Another brake convertion ?
I dont think so, the disc/drum master is different than a drum/drum I believe. I would probably call Master Brakes and ask them.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2010, 10:14 PM   #3
70 Suburban
Rods
you can split the lines use a 70 or older double m/c with it and not use the prop valve
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 02-09-2010, 10:41 PM   #4
Bugeyev8
Bugeyev8's Avatar
why don't you swap the whole front end cross member brakes and all from the 74 to the 64, its a direct bolt on and then you can use the master clyinder and booster
Bugeyev8 is offline   Reply With Quote
Old 02-09-2010, 11:29 PM   #5
mikie 1954
THE TRUCK IS A 4X4. I forgot to say tha part, although I did say the transfer was grumbling. I have thought about makeing it into a 4x4 but that would be down the road.
Old 02-09-2010, 11:53 PM   #6
Captainfab
60-66 Nut
If you want power brakes on your '64 I would recommend switching the master cylinder to one designed for power drum brakes. I have used the one for the '67-'70 pickups but this requires a split brake system. I'm not sure if you could use a '63-'66 power brake master on the newer booster. The dual reservior master cylinder is a better and safer one to use.
Old 02-15-2010, 10:28 PM   #7
mikie 1954
THANKS , now if I use a double m/c out of a 67 to 70 pu do I need any one from those years or a 1/2 ton , 3/4 ton or what. Also why won't the one from the 74 work? I have been reading up on this board about spliting the lines and that does seam to be the best way to go . SORRY for the dumb ? but i just want it strate in my mind. THANKS AGIAN FOR THE INFO & EVERYONES HELP ! MIKIE
Old 02-15-2010, 11:22 PM   #8
70 Suburban
Rods
because the 74 has a pressure check for the disk brakes. you will need a m/c from a drum drum truck.
Old 02-15-2010, 11:31 PM   #9
mikie 1954
SO just go to the auto parts store and ask for a double m/c for a 67-70 pu drum / drum right. again thanks
Old 02-15-2010, 11:33 PM   #10
70 Suburban
Rods
yep
Old 02-15-2010, 11:43 PM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
You will need to cut the rod that goes to the brake pedal and extend it also. You can use the brake rod from the 64 becuase it is adjustable. The later model brake booster rods are too short. Ask me how I know.
The two middle holes will line up and you can drill the two lower holes. You can cut the top of the bracket off as you will probably not be using the upper holes, or you can just leave it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-16-2010, 02:35 PM   #12
mikie 1954
I went out this morning to state takeing the booster off the 74 chevy and realized it is a 1984 pu. DOESthis change things or will it still work, sorry for the wrong info. THANKS Mikie
Old 02-17-2010, 01:49 AM   #13
Captainfab
60-66 Nut
Nope should be the same booster.
Old 02-17-2010, 01:35 PM   #14
mikie 1954
THANK YOU 70 Suburban, Captainfab,& Chevy Fleetside. Thank you gays for the help. Also nice engine bay fleetside. Mikie
Old 02-17-2010, 09:48 PM   #15
rain_man
rain_man's Avatar
anyone got pics of the mod on the push rod
i relly want/need a master for the 61 and i want to use a split line setup
thanks
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 02-18-2010, 12:22 AM   #16
Chevy Fleetside
thanks
I can get a picture of it Thursday for you. I bolted it to the truck but I can take it off. We basically cut the rod in half and used the other side of the 65 rod and welded it up with a sleeve over it.
Old 02-18-2010, 09:06 AM   #17
rain_man
rain_man's Avatar
thanks
NEED A NEW PROJECT
Old 02-18-2010, 09:12 PM   #18
mikie 1954
I have been reading up on splitting the brake lines and cannot find where the font or back line goes to. I think that the line for the front brakes go to the outlet on m/c closest to the firewall ? In the FAQ section this is asked but not answerd. THANKS AGIAN Mikie
Old 02-19-2010, 02:14 AM   #19
Captainfab
60-66 Nut
Which master cylinder are you using? The '67-'70 pickup master?
Old 02-19-2010, 02:31 AM   #20
mikie 1954
The m/c I got is for a 69 chevy 3/4 ton pu. mikie
Old 02-20-2010, 02:29 AM   #21
Captainfab
60-66 Nut
Then I believe the front master cylinder port is the front brakes, and the rear is the rear.
Old 02-28-2010, 04:09 PM   #22
mikie 1954
Got the booster conversion done. I had the wrong fittings to adapt to the double m/c to brake lines so I tried the origanel single m/c and it works great.Will get the right fitting and put on double m/c as soon as I can [40 miles round trip to closest autoparts store]. thanks chevy fleetside for the heads up on the push rod. I had a b--ch of a time getting the bolt that goes from push rod to brake pedle back in until I called one of my daughters to help hold booster up. THANKS TO EVERYONE THAT GAVE GREAT ADDVICE MIKIE!
